Immeadiacy of sensory experience
  • Context: Undergrad
  • Thread starter Thread starter dingansich
    Experience
The discussion explores the nature of sensory experience in relation to the speed of light and the concept of simultaneity. Participants question whether everyday sensory experiences, such as seeing a picture across the room, are immediate or represent a delayed perception due to the time it takes for light to travel and for the brain to process the image. The conversation touches on both scientific and philosophical implications of perception.
  • Some participants propose that when observing distant stars, we see them as they were in the past due to the finite speed of light, questioning if this applies to everyday experiences as well.
  • Others argue that while there is a small delay in sensory processing, it is negligible for everyday experiences, suggesting that we perceive things in near real-time.
  • A participant raises the idea that there are multiple delays involved in sensory experience, including light transmission and brain processing time.
  • Some participants assert that the notion of "now" is observer-dependent and can vary based on the observer's state of motion.
  • There is a contention regarding whether the delays in perception are significant in thought experiments related to the relativity of simultaneity.
  • Some participants express uncertainty about the philosophical implications of these delays and whether they should be considered within the realm of physics or philosophy.
  • Others mention that thought experiments often idealize conditions and may not account for these delays unless they significantly affect the outcomes.
Participants do not reach a consensus on whether the delays in sensory experience are meaningful or significant in the context of physics and philosophy. Multiple competing views remain regarding the implications of these delays on our understanding of perception.
Participants note that the discussion involves complex interactions between physical processes and subjective experiences, which may not be fully addressed by physics alone. The relationship between light transmission, brain processing, and sensory experience remains nuanced and unresolved.
  • #31
DaveC426913 said:
It doesn't. What makes you think it does?
this...
DaveC426913 said:
Because, in one case, it is relevant, in the other it is not.
If you are not grasping why the rays of light emitted from the surface of the train are not relevant to the experiment, I'm afraid we're going to have a lot of trouble helping you further.
  • #32
khemist said:
Actually from another post a while back, it doesn't actually travel slower, but it will seem to have a slower speed in a medium becausethe photon is absorbed and re-emitted by atoms in that medium.
That sounds suspiciously like a trajectory. I think the path is not mechanical like that.
  • #33
I believe DaveC was the one to post in my thread a while back so he would probably be a better person to elaborate.
Say a photon moves through a dense cloud of gas. From what I understand, the time it takes the photon to traverse through the cloud will be less than the time it would take the photon to travel the same distance, because the photon is constantly being absorbed by the electrons and re-emitted, which takes a finite amount of time. This delay will slow the "speed" of light down, though the velocity it has in between the atoms is c.
  • #34
or maybe i should have said why is the light from the surface of the train "not relevant?"
  • #35
dingansich said:
this...
Perhaps you don't understand what a thought experiment is.
In reality, the light delay is there in all cases. In a thought experiment, we eliminate these realities if
1] they do not help explain the point being made and also
2] if they do not hinder the point in principle
For example, when doing relativistic rocket thought experiments, we don't worry about how much fuel will be used to get up to .99c, or how long it takes to turn around and fly back home. These are things that, while they are quite real, do not help illustrate the point being made.
It is assumed that the teller and the recipient of the story are able to understand that the thought experiment only needs to address factors that will have an impact on the experiment.Thought experiments only apply in a carefully limited situation. In your case, the delay of light from source to destination may not hinder the illustration of the point - but if it did - if you could show that it's relevant - then it would indeed have to be accounted for. The thought experiment would have to be modified.
  • #36
If it worked that way, then some photons would arrive ahead of others.
  • #37
I think you wrote that wrong. But I get the idea.
Well, it doesn't really apply effectively to rarified gas clouds. The photons that make it through a gas cloud is space tend to have passed unmolested though the cloud.
  • #39
[/B]
what about if they have an impact on the logical conclusions/interpretations of the experimental results, like length contraction? If I am not wrong doesn't the moving observer in the train have to come to the conclusion that the train's length has contracted in the direction of motion?
  • #40
An observer on the train would not measure the train's length has contracted, but the land in front of it contracted. I believe going into special relativity is going off track from your original questions though.
When you see something in reality, light is emitted from a source such as a light bulb, the light will travel at the speed of light in air, "bounce" off an object and some of the rays of light will go into your eye. Small rods and cones in the back of your eye will convert the information of the light rays into signals that are sent to your brain to interpret and this is what you "see". The time it takes for your eyes to convert the light information to electrochemical signals, for it to be sent to the brain and the brain to process them is a lot longer than the time it took for the light to travel across the room (although much quicker for seeing objects large distances away).
In thought experiments we forget about all of this to make the purpose of the thought experiment clear. We imagine that we can instantly "see" this object without the delay of light or brain processing. If you desire to know what you would see in reality for a special relativity thought experiment you could factor in the time delay, although the point of the thought experiment will be the same e.g. you will still measure time dilation/length contraction of an object moving at .9c, in reality it will just take you longer to make these measurements as the speed of information is limited to c.
  • #41
That may be relevant to the experiment at-hand. If so, it certainly must be accounted for.
You'd have to get specific about what thought experiment you want to talk about for us to determine what's relevant. For example, would you agree that the increasing mass of the train is not relevant?
  • · Replies 26 ·
  • · Replies 33 ·
  • · Replies 35 ·
  • · Replies 26 ·
  • · Replies 22 ·
  • · Replies 23 ·
