Impact considerations
  • Context: Graduate
  • Thread starter Thread starter Mishal0488
    Lagrangian mechanics
The discussion revolves around the dynamics of a spring-mass system in a vertical orientation, particularly focusing on the impact forces that arise when the mass collides with the spring after being in free fall. Participants explore the implications of the spring being massless and the nature of forces during the collision, questioning whether additional considerations are necessary for accurately modeling the system in a finite element analysis (FEA) context.
  • One participant outlines a spring-mass system and questions if extra considerations for impact forces are needed when the mass collides with the spring.
  • Another participant asks whether the spring is massless, indicating that this assumption may affect the analysis.
  • There is a discussion about the nature of the contact force during the collision, with some participants suggesting that the presence of inertia in the spring could lead to longitudinal waves.
  • One participant emphasizes that the mass will experience an acceleration upon collision, which could imply an impulse in the system, while others challenge this notion by stating that there is no instantaneous change of momentum in a massless spring scenario.
  • Examples are provided to illustrate points of discontinuity in the differential equations governing the motion, depending on whether the spring is compressed or relaxed at the moment of impact.
Participants express differing views on the nature of impact forces and whether an impulse occurs during the collision. There is no consensus on the necessity of additional considerations for modeling the impact in an FEA environment.
Participants discuss the implications of the spring being massless and the potential effects of inertia, which may influence the dynamics of the system. The conversation highlights the complexity of modeling impact forces and the need for careful consideration of the system's conditions.
Mishal0488
TL;DR
Impact considerations with differential equations with event handling
Hi guys
I am not going to go into detail with the problem at hand just an outline. Let’s assume a spring mass system where the system acts in the vertical. The equations are simple to derive and event handling on Julia can help with decoupling the system where the mass and spring are no longer in contact. At that point the mass will move vertically up and then come down to collide with the spring again.
When the collision occurs, do extra co desperations need to be defined to account for the impact forces? My reason for the question is that in an FEA environment I do t believe anything further is considered
Is the spring massless?
What do you mean by 'impact forces'? There is only one contact force between spring and mass.
How that contact force looks like on impact depends on whether the spring is massless or has inertia. With inertia you get longitudal waves propagating in the spring.
Spring is massless. By impact forces I am implying moment the spring and mass connect again, the mass will have an acceleration which will obviously cause an impulse in the system. Should that vbs taken care naturally by the direction equations or does it need to have special considerations
Why do you think there will be an impulse? We are talking about an interaction between a mass and a massless spring. There is no instantaneous change of momentum.
Depending on the exact arrangement, there may be an instantaneous change in force. Or an instantaneous change in the rate of change of force.
Consider, for example, a captive spring that is under compression but is restrained against expansion. Suppose the spring is held upright under a falling mass. The mass arrives at the position of the spring. Prior to its arrival, it is in free fall, accelerating downward due to gravity. After arrival, the mass is deflecting the spring and is immediately subject to a finite and increasing non-zero supporting force from the spring. The vertical acceleration of the mass has instantly changed. This is a point of discontinuity for the differential equations describing the motion.
Or consider a spring that is relaxed. It is not restrained against expansion. This spring is held upright under a falling mass. The mass arrives at the position of the spring. Prior to its arrival, it is in free fall, accelerating downward due to gravity. After arrival, the mass is deflecting the spring and is immediately subject to a zero but increasing supporting force from the spring. The vertical acceleration of the mass has not changed. However, the rate of change of its vertical acceleration has instantly changed. This is a point of discontinuity for the differential equations describing the motion.
