Impact of the engine thermostat temperature setting on engine efficiency
The discussion centers on the impact of engine thermostat temperature settings on the thermal efficiency of four-cycle internal combustion engines. Participants explore how varying the cooling system temperature, specifically comparing 160 degrees F and 190 degrees F, affects heat transfer and overall engine performance. The conversation delves into thermodynamic principles, mechanical factors, and the implications of heat energy loss in the context of engine operation.
  • One participant questions whether a cooler thermostat setting (160 degrees F) leads to greater thermal efficiency compared to a hotter setting (190 degrees F), considering the heat energy lost to the cooling system.
  • Another participant argues that the thermodynamic properties of the air-gas mixture are more critical to efficiency than wall temperature, suggesting that mechanical factors like friction and wear may play a significant role.
  • A later reply emphasizes that while heat transfer to the cylinder walls may be negligible during a single combustion cycle, the cumulative effect over many cycles could be significant, with about one-third of fuel heat energy lost to the cooling system.
  • One participant proposes a thought experiment comparing two engines operating at extreme temperatures (100 degrees F and 1,000 degrees F) to illustrate the theoretical implications of temperature on thermal efficiency.
  • Another participant highlights the importance of considering heat energy lost through the exhaust system, suggesting it may overshadow heat exchange with the walls.
  • Some participants express skepticism about the extent of friction losses, referencing specific studies that quantify these losses as a small percentage of developed power.
  • One participant recalls historical references to an "adiabatic engine" developed by Cummins, which purportedly did not require a cooling system, raising questions about the relationship between cooling and efficiency.
Participants express differing views on the significance of wall temperature and friction losses in determining engine thermal efficiency. There is no consensus on whether a cooler or hotter thermostat setting is definitively better for efficiency, and the discussion remains unresolved with multiple competing perspectives.
Participants acknowledge various assumptions, such as the neglect of material limitations at extreme temperatures and the complexity of heat transfer dynamics in engine operation. The discussion also highlights the dependence on specific engine configurations and operating conditions.
onargaroberts
Will a four cycle, internal combustion engine have greater thermal efficiency with a relatively cool jacket water temperature, say 160 degrees F, or a relatively hot water jacket temperature, say 190 degrees F? These specific numbers are only important in as much as they are commonly available thermostats settings.Does the greater temperature difference between hot combustion gasses and the relatively cooler cylinder wall of a system controlled by a 160 degree thermostat drive more heat energy into the cooling system and cause lower thermal efficiency than a system controlled by a 190 degree thermostat? Is any difference likely measureable with commonly available tools and processes.This question assumes that that cooling system has sufficient capacity for the application and at the time being considered, the system temperature is controlled by the thermostat.
Thanks
Science news on Phys.org
For the engine efficiency what matters most is the variations in the thermodynamic properties of the working fluid: the air gas mixture. The entire power cycle happens so fast that the air gas mixture has very little time to exchange heat with the walls and the temperature of the walls has very little effect on the efficiency at least in a direct thermodynamic sense. What the temperature does affect is the strength, wear, and friction of the mechanical parts, and so in that sense the temperature has a very important contribution to the efficiency, but not in a simple obvious thermodynamics way. The temperature can affect how much compression you can handle, or the viscosity of the oil and so how well the rings seal but also how much power is lost to friction etc etc. lots of cascading consequences some of which may show up in the thermodynamic properties of the working fluid (like the compression ratio) but not in a direct obvious way.
Thanks, but it is the "thermodynamic sense" that I'm most interested in (and where I need the most help). Without question, one combustion cycle happens too fast to have a material impact on heat transfer to the cylinder wall and cooling system. But, the cycle happens repeatedly and frequently to the point that roughly 1/3 of the heat energy in the fuel ends up in the cooling system and unavailable to do useful work. Maybe it is necessary to consider a more extreme and unrealistic condition to help me understand what is pretty much a theoretical question. What if there are two engines and cooling systems, equal in configuration and weight of air/fuel mixture (fluid) being fed to them. What if they are both stabilized, one is running at a cooling system temperature of 100 degrees F and the other is running at 1,000 degrees F. Which one is running more thermally efficient - more of the fuels heat energy is doing useful work? We also assume that there are no materials issues in this unrealistic situation. These engines are able to run with the same "motoring losses" at these two very different system operating temperatures.
Thanks again.
onargaroberts said:
... roughly 1/3 of the heat energy in the fuel ends up in the cooling system and unavailable to do useful work.
Yes, but almost all of that is from friction between the moving parts, not direct heating from the hot gasses. (Except the exhaust system which interestingly is not well cooled)
I appreciate that there are important and measurable friction losses but I don't think they are that great. According to an SAE paper on friction losses a test with a Honda four cylinder engine quantified the friction losses at 10% of the developed power. And I'll add that the developed power is only 30% (in round numbers) of the the total heat energy of the fuel. A lot of the fuel's heat energy leaves the complete cycle via the cooling system (again in round numbers, 30%).
I guess I should do a better job of asking my question. It is really just a thermodynamics question. If you have a given engine and it's stabilized operating temperature is controlled by a 190 degree F thermostat, it has some level of thermal efficiency determined by all the resulting operating conditions. If you take that same engine and now control its stabilized operating temperature with a 160 degree F thermostat, does it now operate with greater or less thermal efficiency?
In the engine controlled by the 160 degree thermostat, does the increased temperature gradient between the hot fluid in the combustion chamber and relatively cool fluid in the cooling jacket cause more the of the fuel's heat energy to be driven into the cooling system? That's all I'm really interested in.
Thanks in advance to any and all for your time.
You need to also consider how much heat energy goes out the tail pipe. I am fairly sure the exchange of heat with the walls over one compression and power stroke is a negligible part of the thermodynamics.
Hi buddy,
You basically understand the concept. A great way for you to examine this concept is by comparing the extremes of each condition, hot and cold.
In the first scenario let's assume the surfaces of the combustion chamber are hotter than the combustion event itself during the combustion stroke, in this case the total force from the gases on the combustion chamber surfaces would exceed the total force available from combustion. Because the hotter surfaces of the combustion chamber will further energize the gasses.
At the other extreme let's assume the surfaces of the combustion chamber are set at absolute zero degrees. In this case combustion would not occur.
Thanks for picking up this "dead" question of mine. It didn't seem that I was able to keep responses focused on the essence of my question. Thanks for doing so. The "thought experiment" with extreme conditions is always a helpful tool and that is again true in this case.
I have searched and searched the internet for definitive proof of this same question you have. There is just so much disinformation here and there, and there are zero informative studies or papers on the process. I did find one reference back in the 70s supposedly Cummins made a "adiabatic engine" out of exotic ceramics and "supposedly" didn't need a coolant system. This was for the military, and apparently the goal wasn't for efficiency but was to eliminate the cooling system for a more reliable engine. I never found out if it was actually ever made, besides some references to how it was the world most thermodynamically efficient engine.
I disagree with the thought that the heat transfer into the coolant from combustion alone is negligible. There is just no way friction can account for hundreds of horsepower of heat generated, in which the coolant system alone is rated in the 100s of horsepower.
My question is exactly the same as yours. All these people using lower (160F) thermostats to try to run "more timing" because they automatically think more timing the better, and to try to use suboptimal octane fuels in engines designed for higher octane. Are they being less thermodynamically efficient by running these, I think the answer is definitely yes. However, if they were experiencing a lot of timing being pulled from the knock sensors, is that efficiency loss greater than 40 degrees worth of coolant operating temp difference? I would think the answer to that is yes.
I just want to be able to prove maybe through calculations that you always want to highest thermostat operating temp period. If you are extremely knock limited to where you are way off from MBT, then you might gain something switching to a 160F thermostat, but in doing that you are decreasing thermal efficiency, but it is offset by you being able to restore MBT timing.
  • · Replies 29 ·
  • · Replies 39 ·
10K
19K
  • · Replies 19 ·
  • · Replies 67 ·
