Implicit finite difference method
30 replies · 7K views · last reply
mathmari
MHB
Hey! :o
I have a implicit finite difference method for the wave equation.
At step 0, we set: $W_j^0=v(x_j), j=0,...,J$
At the step 1, we set: $W_j^1=v(x_j)+Dtu(x_j)+\frac{Dt^2}{2}(\frac{v(x_{j-1})-2v(x_j)+v(x_{j+1})}{h^2}+f(x_j,0)), j=0,...,J$
Can that be that at the step 1 $j$ begins from $0$ and ends at $J$?
Mathematics news on Phys.org
mathmari said:
Hey! :o
Possibly, or perhaps $j=1..J-1$, so that all values are defined.
Otherwise you will need values for $v(x_{-1})$ and $v(x_{J+1})$ that are currently not defined.
Ok! Thank you! (Happy)
I have also an other question..
I want to implement a program in C for this method..
The wave equation is:
$$w_{tt}(x,t)=w_{xx}(x,t)+f(x,t), \forall (x,t) \in [0,1]x[0,1]$$
$$w(0,t)=w(1,t)=0, \forall t \in [0,1]$$
$$w_t(x,0)=u(x), \forall x \in [0,1]$$
$$w(x,0)=v(x), \forall x \in [0,1]$$
where $u(0)=u(1)=0$
The method is:
At the step 1, we set: $$W_j^1=v(x_j)+Dtu(x_j)+\frac{Dt^2}{2}(\frac{v(x_{j-1})-2v(x_j)+v(x_{j+1})}{h^2}+f(x_j,0)), j=1,...,J-1$$
For $n=1,...,N-1$ we do the following:
At the step n+1 we find the $(W_j^{n+1})_{j=1}^{J-1}$ as the solution of the linear system from:
$$\frac{W_j^{n+1}-2W_j^n+W_j^{n-1}}{Dt^2}=\frac{W_{j-1}^{n+1}-2W_j^{n+1}+W_{j+1}^{n+1}}{2h^2}+\frac{W_{j-1}^{n-1}-2W_j^{n-1}+W_{j+1}^{n-1}}{2h^2}+f(x_j,t_n), j=1,..,.J-1$$
$W_0^{n+1}=W_J^{n+1}=0$
The approximations $(W_j^{n-1})_{j=1}^{J-1}$ are saved at the vector $A$, and the $(W_j^{n})_{j=1}^{J-1}$ at $B$.
So we could find the approximations by solving a system of the form $Ax=b$, right?
I calculated the $b$ as followed:
Code:
for(j=1; j<J-1; j++){
	b[j-1]=A[j-1]/(2*h*h)-A[j]*(h*h+Dt*Dt)/(Dt*Dt*h*h)+A[j+1]/(2*h*h)+2*B[j-1]/(Dt*Dt)+f(xx(j,J),tn(n,N));
b[J-2]=A[J-2]/(2*h*h)-A[J-1]*(h*h+Dt*Dt)/(Dt*Dt*h*h)+2*B[J-2]/(Dt*Dt)+f(xx(J-1,J),tn(n,N));
Is this correct?
$v(x)=0, u(x)= \pi x (1-x)$
$f(x,t)= \pi^2 x^2 (x-1)sin(\pi x t)+2 \pi t cos(\pi x t)+(1-x) \pi^2 t^2 sin( \pi x t)$
the exact solution is $w(x,t)=sin( \pi x t)(1-x)$
Also I want to find the errors ($max_{1 \leq n \leq N} ( max_{1 \leq j \leq J-1} |W_j^n-w(x_j,t_n)|)$).These are what I've found:
For $J=N=10: 0.099211$
For $J=N=20: 0.049875$
Are these errors correct for these J and N?
To check if my program is correct, could you tell me if the following results of the approximations for $J=N=5$ are right?
n=1:
0.198483
0.292070
0.283378
0.181988
n=2:
0.269957
0.424158
0.434060
0.326570
n=3:
0.329534
0.569906
0.628201
0.522819
n=4:
0.397004
0.727531
0.811541
0.764543
Mmh, for $n=1$ I get:
$$W^1 = \begin{bmatrix}
0 \\
0.100531 \\
0.150796 \\
0.150796 \\
0.100531 \\
\end{bmatrix}$$
0 \\
0.100531 \\
0.150796 \\
0.150796 \\
0.100531 \\
\end{bmatrix}$$
Ok.. But when we solve the system do we not get as answer the approximations $W^{n+1}$? So for $n=1$ we get $W^2$, or did I misunderstand it?
This $W^1$ is from the step 1, right?
Yep.
For more steps, I get:
$$W_{j=1..J-1}^n = \begin{bmatrix}
0 & 0.100531 & 0.167758 & 0.190311 & 0.183852 & 0.178421 \\
0 & 0.150796 & 0.252344 & 0.279416 & 0.244453 & 0.191595 \\
0 & 0.150796 & 0.246062 & 0.256217 & 0.191528 & 0.095445 \\
0 & 0.100531 & 0.156116 & 0.146507 & 0.08322 & -0.002342 \\
\end{bmatrix}$$
Hmm... that is not the same as what you have... :o
I like Serena said:
Yep.
\end{bmatrix}$$
I calculated the approximation $W_j^2$ by hand and I get the following system ( I hope I made no mistakes at the calculations :o ):
$\begin{bmatrix}
50 & -12.5 & 0 & 0\\
-12.5 &50 &-12.5 &0 \\
0 & -12.5 & 50 &-12.5 \\
0 &0 & -12.5 & 50
\end{bmatrix} W_j^2=\begin{bmatrix}
6.271728\\
8.580236 \\
8.243136 \\
5.557183
\end{bmatrix}$
So $W_j^2=\begin{bmatrix}
0.1984\\
0.2921 \\
0.2834 \\
0.1820
\end{bmatrix}$
$\begin{bmatrix}
0 &0 & -12.5 & 50
6.271728\\
8.580236 \\
8.243136 \\
5.557183
\end{bmatrix}$
0.1984\\
0.2921 \\
0.2834 \\
0.1820
\end{bmatrix}$
I've got:
$$\begin{bmatrix}
75 & -25 & 0 & 0\\
-25 &75 &-25 &0 \\
0 & -25 & 75 &-25 \\
0 &0 & -25 & 75
6.271728\\
8.580236 \\
8.243136 \\
5.557183
\end{bmatrix}$$
:eek:
I like Serena said:
I've got:
$$\begin{bmatrix}
75 & -25 & 0 & 0\\
-25 &75 &-25 &0 \\
0 &0 & -25 & 75
6.271728\\
8.580236 \\
8.243136 \\
5.557183
\end{bmatrix}$$
:eek:
The elements of the diagonal of the matrix are the coefficients of $W_j^{n+1}$, aren't they? So they are equal to $\frac{1}{Dt^2}+\frac{1}{h^2}$.
The elements of the upper diagonal are the coefficients of $W_{j+1}^{n+1}$, so they are equal to $- \frac{1}{2h^2}$.
And the elements of the lower diagonal are the coefficients of $W_{j-1}^{n+1}$, so they are equal to $- \frac{1}{2h^2}$.
Have I calculated something wrong?
Could you tell me how you found that the elements of the diagonal are $75$ and the elements of the lower and upper diagonal $-25$?
I rearranged the formula you gave earlier and found for the diagonal elements $$\frac{1}{Dt^2}+\frac{2}{h^2}$$ and for their neighbors $$- \frac{1}{h^2}$$.
Hmm, you must have rearranged it differently from how I did it. :o
From the following formula, do we not use the terms in red?
$\frac{W_j^{n+1}}{Dt^2}$$+\frac{-2W_j^n+W_j^{n-1}}{Dt^2}=$$\frac{W_{j-1}^{n+1}}{2h^2} - \frac{2W_j^{n+1}}{2h^2} + \frac{W_{j+1}^{n+1}}{2h^2}$$+\frac{W_{j-1}^{n-1}-2W_j^{n-1}+W_{j+1}^{n-1}}{2h^2}+f(x_j,t_n)$
So $\frac{W_j^{n+1}}{Dt^2}-\frac{W_{j-1}^{n+1}}{2h^2}+ \frac{W_j^{n+1}}{h^2}- \frac{W_{j+1}^{n+1}}{2h^2}$$=\frac{2W_j^n-W_j^{n-1}}{Dt^2}+\frac{W_{j-1}^{n-1}-2W_j^{n-1}+W_{j+1}^{n-1}}{2h^2}+f(x_j,t_n)$
$W_j^{n+1}(\frac{1}{Dt^2}+\frac{1}{h^2})+W_{j-1}^{n+1}(\frac{-1}{2h^2})+ W_{j+1}^{n+1}(\frac{-1}{2h^2})=\frac{2W_j^n-W_j^{n-1}}{Dt^2}+\frac{W_{j-1}^{n-1}-2W_j^{n-1}+W_{j+1}^{n-1}}{2h^2}+f(x_j,t_n)$
How did you rearrange it??
I made a mistake. :o
Now I get the same matrix as you have.
As a result I get:
$$W = \begin{bmatrix}
0 & 0.100531 & 0.198483 & 0.293286 & 0.386943 & 0.482468 \\
0 & 0.150796 & 0.29207 & 0.416943 & 0.521666 & 0.603338 \\
0 & 0.150796 & 0.283378 & 0.38187 & 0.433659 & 0.42937 \\
0 & 0.100531 & 0.181988 & 0.225558 & 0.216531 & 0.15098 \\
\end{bmatrix}$$
... but that is still not quite the same as what you had... :o
As a result I get:
\end{bmatrix}$$
I made a mistake at the way I calculated the vector $b$.
Now I have the same results as you have! (Smirk)
(Wait)
But now having changed some values, the function that calculates $b$ is the following:
Code:
void *b(double A[],double B[],double C[],int J, int N, int n){
	double *pointer=&C[0],Dt=T/(double)N, h=(c-a)/(double)J;
	int j;
	for(j=1; j<J; j++){
		C[j-1]=A[j-2]/(2*h*h)-A[j-1]*(h*h+Dt*Dt)/(Dt*Dt*h*h)+A[j]/(2*h*h)+2*B[j-1]/(Dt*Dt)+f(xx(j,J),tn(n,N));
		pointer=&C[j-1];
		//printf("%lf\n",*pointer);
		pointer++;
How can that be that it works, when at the first iteration for j=1 we have A[j-2]=A[-1] ? :confused:
Good!
(Wait)
Aren't all values of A zero in the first iteration?
Then it won't matter much which index on A you are using.
However, the value for A[-1] is undefined and will often contain an unpredictable value.
It seems you've been in "luck" as it would appear A[-1] turned out to be zero.
So should I change these indices or let the for loop be so as it is now?
Slightly modified quote from The Ten Commandments for C Programmers:
Thou shalt not index an array outside of its specified range, for chaos and madness await thee.​
(Evilgrin) (Swearing) (Angel)
Ok! Then could I write the function like that?
Code:
	int j;
	C[0]=-A[0]*(h*h+Dt*Dt)/(Dt*Dt*h*h)+A[1]/(2*h*h)+2*B[0]/(Dt*Dt)+f(xx(1,J),tn(n,N));
	pointer=&C[0];
	for(j=2; j<J; j++){
		pointer=&C[j-1];
		pointer++;
Yep. You can.
But only if the array A has J+1 entries, since you refer to A[J]. :o
I like Serena said:
Yep. You can.
(Thinking)
At which point do I refer to A[J]?? :confused:
Do you mean at the following for-loop?
Code:
for(j=2; j<J; j++)
But isn't it $j=2,...,J-1$, so $A[J-1]$?
mathmari said:
(Thinking)
Code:
for(j=2; j<J; j++)
You're right. So your array A should have J elements.
Does it?
Does it?
I have defined the array A so:
Code:
double A[J-1];
Code:
double A[J-1];
But then A[J-1] is out-of-range! :eek:
And it will be unpredictable which results you'll get.
A ok..So you mean that I should define the array so:
Code:
double A[J];
Code:
double A[J];
Yes.
And you should also make sure it is initialized to zero.
Is it?
I like Serena said:
Yes.
Is it?
I have initialized it as followed:
Code:
for(j=0; j<J; j++){
	A[j]=0;
Code:
for(j=0; j<J; j++){
	A[j]=0;
Good! ;)
I like Serena said:
Good! ;)
I read again the exercise and I saw that we need an array $A$ with $J-1$ elements since the zero elements don't have to be saved. That means that I have to define this array so: double A[J-1]; , or not?
So I changed the function that calculates $b$:
Code:
	int j;
	pointer=&C[0];
	for(j=2; j<J-1; j++){
		pointer=&C[j-1];
		pointer++;
	C[J-2]=A[J-3]/(2*h*h)-A[J-2]*(h*h+Dt*Dt)/(Dt*Dt*h*h)+2*B[J-2]/(Dt*Dt)+f(xx(J-1,J),tn(n,N));
	pointer=&C[J-2];
Now there is no $A[J-1]$..Is it correct now?
Code:
	int j;
	pointer=&C[0];
		pointer=&C[j-1];
		pointer++;
	pointer=&C[J-2];
Yep. That is correct.
Btw, any reason that the return value is "void *" instead of "void"?
And that you execute "pointer++" when you make no use of the incremented value?
