Improper integral of integral test
The discussion revolves around evaluating the improper integral to determine the convergence of the series ∑ k / e^(k/5). Participants analyze the function f(x) = xe^(-x/5), confirming it is continuous, positive, and decreasing for x > 5, thus establishing the lower limit of integration. Various integration techniques, including integration by parts, are debated, with the correct evaluation leading to the conclusion that the integral converges to 50/e. The conversation highlights confusion over the integration process and the importance of correctly applying limits in improper integrals. Ultimately, the integral's evaluation is crucial for confirming the convergence of the series.
ProPatto16
determine the value of the improper integral when using the integral test to show that \sum k / e^k/5 is convergent.
answers are given as
a) 50/e
b) -1 / 5e^1/5
c) 5
d) 5e
e)1/50e
f(x) = xe^-x/5 is continuos and positive for all values x>0
to see where its decreasing, take derivitive and see where f'(x) < 0
f'(x) = -x/5*e^-x/5 + e^-1/5
this function is < 0 only when x>5... so f(x) is continuous, positive and decreasing when x>5... therefore lower limit is 5.
\intf(x).dx = \int xe^-x/5 .dx
= [-x/5*e^-x/5 + e^-1/5] between b and 5 where b replaces infinity.
* Note here that f'(x) = \int f(x)... I am not sure why but that's what i got.
if i sub in the lower bound 5 i get -e^-1-e^-1
which doesn't match anything :S
stuckkkkkk.
This is ambiguous. Is the function the first or the second?
\frac{k}{\frac{e^k}{5}}
or
\frac{k}{e^{k/5}}
a) 50/e
b) -1 / 5e^1/5
c) 5
d) 5e
e)1/50e
stuckkkkkk.
OK fine, 5 is the lower limit of integration. It turns out that it doesn't really matter in this case, so a problem like this is really somewhat against the spirit of analysis.
Again, there are problems with your integration that go beyond terminology. First of all, assuming the first term is your 'uv term', it's wrong because when you integrate e^(-x/5), you shouldn't get the -1/5 out front. Note that when you differentiate e^(-x/5), you do in fact get (-1/5)e^(-x/5), so do you see now how to integrate e^(-x/5)?
Secondly, please show the integration of v*du because I don't think what you have there is correct.
the function, mark,is the second one you have there. e^(k/5).. ill get back to this one soon, I am still fiddling with the other one you guys are helpin me with. thanksss
hey guys, i re calculated the integral using product rule and substitution... i got a differnet answer, ill show you..
product rule: (uv)'=uv'+vu'
f(x)=xe^(-x/5)
let u=x therefore u'=1
let v=e^(-x/5) and use subsititution to find v'
v=e^(-x/5), let u=(-x/5) therefore v=e^u so v'=e^u=e^(-x/5)
then \int f(x).dx= xe^(-x/5) + e^(-x/5)
im sure the maths is right there I am just not sure about that + sign and whether it should be a -... should my substitution be u=x/5 then have e^-u?? so then derivitive is -e^(-x/5)
after that I am not sure how to incorporate the bounds when the ubber bound is b (substituted for infinity) and the lower bound is 5.
no wait, that's wrong.
v'=-5e^(-x/5)... i forgot to do anything with my substitution of u
so \sum f(x).dx = -5xe^(-x/5) + e^(-x/5)
im sure that's right. and don't worry about the u part in the previous post... it works out the same with or without the negative.
Thats all wrong... i derived -.- so dumb
using by parts..
\int f(x)g'(x) .dx = f(x)g(x) - \int g(x)f'(x)
let f(x) = x, so f'(x) = 1
and g'(x)= e(-x/5) so g(x)=-5e(-x/5)
so \int xe(-x/5) .dx = x*-5e(-x/5) - \int -5e(-x/5)*1
= -5xe(-x/5) - e(-x/5)
there.
so that's the integral... but i don't know how to get from there to "the value of the improper integral", which is what i need for the answer.
Good, I think that looks right. Now for the first term, call it h(x) = (-5)xe^(-x/5), you need to take the difference h(b) - h(5) and take the limit of this as b goes to infinity. Here, recall that the exponential function dominates polynomials.
For the second term (the integral) do something similar. Evaluate the integral with lower limit of integration 5 and upper limit b, and let b go to infinity.
As b -> infinity, e^(-b/5) is 0. so all b terms become zero... so:
lim [-5xe^(-x/5) - e^(-x/5)] with upper bound b and lower bound 5 becomes
lim [(0 - 0) - (-25e^(-1) - e^(-1)] which becomes
lim [0 - 0 + 25e^(-1) + e^(-1)]
and if i do it seperately...
take first term, -5xe^(-x/5) :
= (-5b^(-b/5) - -5(5)^e(-5/5))
= (0 + 25e^(-1))
= 25e^(-1)
second term, -e^(-x/5)
= -e^(-b/5) - -e^(-5/5)
= 0 + e^(-1)
= e^(-1)
Almost, you have a 5 in front of the integral to start with. What is the integral of e^(-x/5) again?
integral of e^(-x/5) is
-5e^(-x/5)
but why am i integrating again? i can see there might be a little confusion where i did my integral... i skipped a step near the end... but the complete integral of the given function is
so howcome i need to integrate the second term?
ohhh the by parts integration is wrong towards the end.
the second last line reads:
and that second integral there is \int -5e(-x/5)*1
= -5 \int e^(-x/5)
= -5 * -5e(-x/5)
= 25e^(-x/5)
so the complete integral should be:
= -5xe(-x/5) - 25e(-x/5)
and then somewhere in the maths I've gone wrong with the signs... cause then if they're both +ve instead of -ve... the answer is 50e^(-1)
Nowhere in this thread do I see a definite, improper integral. To determine the convergence of the given series, evaluate this integral.
\int_1^{\infty} xe^{-x/5}dx
Since this is an improper integral, you need to evaluate this limit to determine the value of the integral.
\lim_{b \to \infty}\int_1^b xe^{-x/5}dx
Click either of the expressions above to see my LaTeX code.
