Impulse momentum theory, a ball strikes a wall dunno if i got it right?
A ball with a mass of 0.15 kg and an initial velocity of 5 m/s strikes a wall and rebounds with a velocity of 3 m/s, making contact for 0.1 seconds. The calculation for the force exerted by the wall involves using the impulse-momentum equation, resulting in an average force of 12 N. The confusion arises from the direction of the velocities, as they are vectors, and the sign of the force indicates direction. When the final velocity is considered negative, the force is interpreted as 12 N directed toward the wall, meaning the wall exerts an equal force of 12 N on the ball in the opposite direction. Understanding the signs chosen for velocity is crucial in determining the correct interpretation of the force's direction.
girl52
a ball w/ mass of .15kg and a velocity of 5m/s strikes a wall and bounces right back with v=3m/s. ball is in contact with wall for 0.1 sec, how much force did the wall exert on the ball?
Ft=mvf-mvi
F=?
t=0.1
m=.15
vf=3m/s
vi=5
0.1F=(.15*3)-(.15*5)
0.1F= -.30
F= -3 N
How could the force be negative?? did i do something wrong?
Velocity and momentum are vectors, which means you have to take into account the direction of the velocities (plus or minus) before and after the collision. Your answer is not correct. If the force is negative, what does that imply?
OOOH okayy i don't know how i forgot that!
i just don't know which one is negative. i made the inital velocity negative, and i got 12N for the answer...is that right?
i got:
0.1F=(.15*3)+(.15*5)
F=12
when i made the final velocity negative i got 3N
im so confused
12 N for the average force is correct, but what is the direction of the 12 N force? You can choose any direction as negative, as long as you choose the opposite direction as positive. If you make the final velocity negative, then the initial velocity is positive. In which case,
0.1F = .15*(-3) - (.15*5)
F = - 12 N
How do you interpret the minus sign??
F = - 12 N
um...12N toward the wall?
The ball exerts an average 12 N force on and pointing toward the wall, so the wall must exert an average 12 N force on the ball in the direction, per Newton 3, pointing away from? or toward? the wall. The sign of the force corresponds to the signs you chose for the direction of the velocities.
