Impulse-steel ball dropped on steel slab
  • Thread starter Thread starter herbally
    Ball Steel
The problem involves a steel ball dropped from a height of 2.00 m onto a horizontal steel slab, which rebounds to a height of 1.60 m. The objective is to calculate the impulse experienced by the ball during the impact.
  • Participants discuss using conservation of energy to determine velocities before and after the impact. Questions arise regarding the direction of momentum and the sign of the initial velocity just before the collision.
Some participants have provided guidance on considering the vector nature of momentum and velocity. The original poster expresses confusion but later indicates a realization of the mistake. There is an acknowledgment of the importance of correctly interpreting the signs of the velocities involved.
The discussion reflects a common challenge in understanding the implications of direction in momentum calculations. The original poster mentions fatigue from extended study, which may influence their reasoning.
herbally
1. Homework Statement
mass of steel ball = 40g = .04 kg
h1 = 2.00 m
h2 = 1.60 m
A steel ball is dropped from height of 2.00 m onto horizontal steel slab, rebounds to height of 1.60m. Calculate impulse of ball during impact.
2. Homework Equations
impulse J = F*dt
J = P2 - P1
K0 + U0 + Wother = Kf + Uf
I tried to get velocities using conservation of energy in two steps; from drop to impact; from impact to rebound.
.04kg(9.8m/s2)(2m) = 1/2(.04kg)v2
v = 6.26m/s
1/2(.04kg)v2 = .04kg(9.8m/s2)(1.6m)
v = 5.6m/s
then I used ΔP = .04kg(5.6m/s - 6.26m/s) = -.0264
Book shows answer to be .47N*s
Not sure where I'm botching this up. Any help is appreciated.
Hi, Herbally. This is a common problem that is easy to slip up on. Remember that momentum and velocity are vector quantities (with direction). If you take upward as the positive direction, then what is the sign of the initial velocity (momentum) just before the collision?
Naturally the initial velocity is negative. I'm failing to see the correlation. Then again, I've been doing physics for about 3 hours straight so all the numbers are beginning to run together.
Perhaps another nudge? Thanks.
WOW. NM. I'm rum-dumb at this point. I got it. Thanks a ton.
OK. So, the initial velocity is -6.26 m/s. You will have to subtract this negative number from 5.6 m/s. What is 5.6-(-6.26)? [Edit: I see you got it! Great!]
17K
  • · Replies 21 ·
12K
