Undergrad E Vector in E=mc2? Scalar Multiplication & Vectors
  • Thread starter Thread starter andrecoelho
    E=mc2 Vector
The discussion centers on the classification of energy as a vector or scalar, particularly in the context of the equation E=mc² and the potential energy formula U=mgh. Participants clarify that energy is a scalar quantity, while potential energy is derived from scalar and vector components, specifically noting that gravitational force is a vector but gravitational potential energy is a scalar. The conversation highlights the distinction between energy and energy flux, emphasizing that the latter can be a vector, but energy itself cannot be classified as such. Ultimately, the consensus is that energy is defined as a scalar, and this classification is upheld by mathematical and physical principles. The thread concludes with a firm assertion that energy is not a vector.
andrecoelho
TL;DR
E=mc2 , E vector?
If the energy is a vector, which as i understand for example, the potential energy , U=mgh, where g is the gravitational force, Then U is the product of scalars and vectors, so its a vector
In that case being E a vector , can it be equal to mc2 (each are scalars). Like mulitplication of scalars are not vectors...
Energy is not a vector.
But isn't energy the exorthation of force in a body?
I have no idea what “exorthation” means. But regardless of what that word means, energy is not a vector. Force is a vector, but that doesn’t mean that everything that has something vaguely to do with force is also a vector.
Likes Vanadium 50 and PeroK
exorthaton -> the effect of applying the force
Can you explain why? Particulary the U=mgh formula
andrecoelho said:
Summary:: E=mc2 , E vector?
In U=mgh, the g is not the gravitational force--- m\vec g is the gravitational force (and \vec g is the gravitational field).
More completely, U=-(m\vec g)\cdot \vec h (as minus the work done by the gravitational force).
The dot-product of two vectors is a scalar. So, U is a scalar.
In fact, the gravitational potential gy is a scalar field
(so minus its gradient is the gravitational field)
and so the gravitational potential energy mgy is a scalar.
Note that ordinary kinetic energy (from the work-energy theorem) is a scalar K=\frac{1}{2}mv^2.
Energy is a scalar.
Likes Bandersnatch, martinbn, Dale and 1 other person
The ##g## in that formula is the magnitude of the gravitational force: ##g = |\vec g|##. More generally, we have $$U = -\frac{GMm}{r}$$
In any case, potential energy is not a vector; nor is any form of energy. Kinetic energy is ##\frac 1 2 mv^2##, where again ##v = |\vec v|## is the magnitude of the velocity. So, KE is also a not a vector.
As you've posted this in relativity forum, the energy of a particle is a component of the energy-momentum four vector: $$\mathbf{p} = (E, p_x, p_y, p_z) = (E, \vec p)$$ In that sense, energy is a component of a four-vector.
Likes vanhees71
Keeping ##c## it's
$$(p^{\mu})=(E/c,\vec{p}).$$
One should also use invariant masses and only invariant masses in relativity, and thus the relation between energy and momentum of a particle reads
$$p_{\mu} p^{\mu}=\frac{E^2}{c^2}+\vec{p}^2=m^2 c^2$$
or
$$E=c \sqrt{(m c)^2+\vec{p}^2}.$$
In terms of the coordinate velocity ##\vec{v}=\vec{p} c^2/E## it reads
$$E=\frac{m c^2}{\sqrt{1-\vec{v}^2/c^2}}.$$
The famous formula by Einstein should read (BTW also according to Einstein himself!)
$$E_0=m c^2,$$
where ##E_0## is the energy as measured in the rest frame of the particle.
In general a force and its associated potential energy have the relationship: ##\vec F = -\nabla U##. Since ##\nabla## is an operator that converts a scalar into a vector it is clear that ##U## must always be a scalar.
In the case of a uniform gravitational field we have $$\vec F = m \vec g = -\nabla (mgh) = -\nabla U$$ where on the left hand side ##\vec g## is a vector pointing downwards and on the right hand side ##g## is the magnitude of that vector.
Likes horacio torres, cianfa72, vanhees71 and 1 other person
What is the relevance of attributing a unit to a expression? does that mandate that the quantity is vectorial?!
what is the relation between a joule and the fact that its possible a vector?
And i still don't get it, h is not a vector , is distance
" If you accept that energy, by definition, is a scalar function," , i can't just assume that something just by definition, its not an axiom. If the math is incorrect, its also incorrect in terms of physics, because physics use exclusive maath
is the h in the formula a vector (lisnt length a scalar)??
Energy can be transferred one side to another, hence could be a vector the problem remains,
is energy released to every part of a body, and each part is the same? or is there a parts of the body with more energy
than others? Just because we don't know what happens to energy after being transferred (for example The force used to store energy in a rubber band has a certain direction,
that doesn't mean its not a vector, so one thing is sure, energy can be trasferred (which applies being vector) . If you don't know where the energy goes,
how can you know its not a vector
Does the energy gets released equally?
or the whole body has energy (where other parts dont). Does energy already remeains at a body and energy gets added
beign released means going into a direction or several
  • Skeptical
  • Wow
Likes phinds, weirdoguy and PeroK
No, assigning units in no way makes the quantity a vector. I am not sure what would possibly lead you to believe that.
Why not? Definitions are true by definition.
Actually, no. What you are thinking of is energy flux, not energy. Energy flux density is a vector.
We know that it is not a vector because it is defined to not be a vector. Since it is a definition it is true by definition.
This is nonsense. Money can also be transferred. Money is not a vector. Transferred applies more to conserved quantities than to vector quantities.
There really is no way around this and absolutely no ambiguity on this topic whatsoever. Energy is not a vector.
Since there is literally nothing more to say on this topic and since you seem disinclined to actually learn anything here, this thread is closed.
Likes cianfa72 and berkeman
  • · Replies 35 ·
  • · Replies 0 ·
  • · Replies 16 ·
  • · Replies 48 ·
