Inclined slope with acceleration
20 replies · 4K views
devanlevin
in the following question, a box with a mass of m is tied to a pole at the top of a slope with an incline of (alpha), the whole slope accelerated at "a", find the tension "T" in the rope.
http://picasaweb.google.com/devanlevin/DropBox?authkey=sbH95pBl_D8#5273613370813875458
what i did was:
F=T-mg[sin(alpha)]=ma[cos(alpha)]
T=m[(gsin(alpha))+(a(cos(alpha))]
T=m(cos(alpha))[tg(alpha)-a]
which according to the answer sheet is only a part of the correct answer,
it says this is correct when-- a<g/tg(alpha)
but when a>g/tg(alpha)
then
T=m*sqrt(a^2+g^2)
why specifically a>g/tg(alpha) or a<g/tg(alpha), what happens physically at that point? is that the critical acceleration where N=0??
how do i see this from the equations?, the second T, seems to me like the sum of the 2 vectors ma and mg, what is the logic in doing that
Hi devanlevin! :smile:
what i did was:
No, you've left out N. :frown:
but N is 90 degrees to the x-axis I am talking about, the axis parallel to T, look at the picture,
(have an alpha: α and a square-root: √ :wink:)
Sorry, I should have been more specific. :redface:
You didn't consider what hapens when N is zero …
then the box is hanging on for dear life (at an angle smaller than α). :biggrin:
thats the second case, the one i noted i don't know how to build the equation for,
when a>g/tg(alpha)
devanlevin said:
how do i find this
The rope is now at an unknown angle.
Just write the horizontal and vertical equations, and solve by eliminating the angle. :smile:
(or just use a vector triangle :wink:)
from what i understand,
i say, when a>g/tg(alpha) N=0, and so the total force is sqrt((T)^2+(mg)^2) and that is the size of the force on the box, now that is equal to ma?
so T=sqrt((ma)-(mg)^2)
but that isn't right, where am i going wrong,,, can you please show me how to solve this both ways, both with equation and with vector triangle
i say, when a>g/tg(alpha) N=0, and so the total force is sqrt((T)^2+(mg)^2) …
No, that is not the total force …
T and g are not perpendicular.
(or just use a vector triangle)
right, so how would i divide my axises, parallel to a or parallel to t??
if parallel to a
F=Tcos(alpha)=ma
if parallel to a
F=F=T-mg[sin(alpha)]=ma[cos(alpha)]
which is what i did in the 1st place
if parallel to a
F=Tcos(alpha)=ma …
waaah! :cry:
it's not alpha!
and you need two axes!
so when a<g/tg(alpha) i divide the vector components parallel to T
and when a>g/tg(alpha) i divide them parallel to a
shouldnt i use the same x,y axises in both cases? here once i look at it on the slopes axis once on the grounds axis?? how do i know how to divide and when
No, you can use any pair of axes in both cases …
the only difference is that if a ≤ g/tanα, then the rope is at angle α, but if a > g/tanα, the rope is at an angle less than α.
i can only see the 1st case with an axis parallel to t
T=m(cos(alpha))[tg(alpha)+a]
and with a regular axis, parallel to a for the second case
Ma(y)=0=Mg-T(y)
Ma(x)=ma=T(x)
T=sqrt[(mg)^2 + (ma)^2]
if i try the other way what are my equations? i get
for the 1st case
Ma(x)=ma=Tcos(alpha)-Nsin(alpha)
Tx=Nsin(alpha)+ma
Ma(y)=0=Tsin(alpha)+Ncos(aplha)-mg
Ty=mg-Ncos(alpha)
then to find T==>Tx^2+Ty^2
but i get an equation with N in it
could you please show me the equations you get for each axis
for the 1st case
Tx=Nsin(alpha)+ma
Ty=mg-Ncos(alpha)
Well that's pretty good :approve:
you've tried both methods (x-y axes and T-N axes), and you've got the right equations for them (except there should be minus signs in the Tx equation) …
you just haven't spotted the trick for solving the x-y one :wink:
you simply need to eliminate N …
so multiply the first equation by cosα, and the second by sinα, and add! :smile:
where should there be a minus?? don't see it
look at your own diagram … a is to the left, and n is to the right
X+ in the direction of a
Ma(x)=ma=Tcos(alpha)-Nsin(alpha) (here there is a minus)
if i wan Tcos(alpha) on one side of the =, i move -Nsin(alpha) to the side of ma,
becomes + Nsin(alpha)
Tx=Nsin(alpha)+ma
still don't see it
did what you said using my equations, without the - and it works, you sure there is a minus i haven't written
thanks for the help, could you please look at this thread, desperately need help with it
https://www.physicsforums.com/showthread.php?p=1982691#post1982691
oops!
Sorry … you're right … no extra minus. :redface:
