Independent and Dependent Variables
1 reply · 4K views · last reply
ditto_299
I'm doing a lab where i need to calculate the heat energy, or enthalpy using the equation
(delta) H = m x c x T
my reactions are going to be of a strong acid and a strong base:
Sulfuric Acid + Sodium Hydroxide→ Sodium Sulfate + Water
and of a wek acid and the same strong base:
Ethanoic Acid + Sodium Hydroxide → Sodium Ethanoate + Water.
So, for the planning of the lab, I have to put in the independent and dependent variables. For independent I intially put that what doesn't change is the strong base, and also time. For the dependent variables, i put the temperature of the reaction. However, my teacher says that I should still revise this. Any suggestions or help?
thnx
Look more closely at 'm', 'c', and 'T' (probably 'delta T'). Dependent variables are things you can control... like how much of a reagent to add. Independent variables are things you can't control or that you are measuring... like how much the temperature changed during a process given a certain amount of reagent A and B you used.
