Independent fields' components in Maxwell's equations
This discussion focuses on the independent components of electric and magnetic fields in Maxwell's equations within a source-free, isotropic, linear medium. The equations are reformulated to express the transverse field components as functions of the longitudinal components, specifically E_z and H_z. The discussion highlights the challenge of proving that all six field components can be derived from just these two scalar functions. A direct approach is suggested to express E_x, E_y, H_x, and H_y in terms of E_z and H_z, utilizing the relationships established in the equations.
  • Understanding of Maxwell's equations in electromagnetism
  • Familiarity with wave propagation concepts in isotropic media
  • Knowledge of vector calculus, particularly divergence and curl operations
  • Experience with complex exponential functions in wave equations
  • Study the derivation of wave solutions in Maxwell's equations
  • Explore the use of Hertz Vector potentials in electromagnetic theory
  • Investigate the implications of transverse and longitudinal field components
  • Learn about the mathematical techniques for proving field component dependencies
Electromagnetic theorists, physicists, and electrical engineers seeking to deepen their understanding of Maxwell's equations and their applications in wave propagation and field interactions.
EmilyRuck
In a source-free, isotropic, linear medium, Maxwell's equations can be rewritten as follows:
\nabla \cdot \mathbf{E} = 0
\nabla \cdot \mathbf{H} = 0
\nabla \times \mathbf{E} = -j \omega \mu \mathbf{H}
\nabla \times \mathbf{E} = j \omega \epsilon \mathbf{E}
If we are looking for a wave solution, traveling along the z direction, with k = k_z = \beta, that means
\displaystyle \frac{\partial}{\partial z} = e^{-j \beta z}
and the above equations (after some steps) become\displaystyle \frac{\partial E_x}{\partial x} + \frac{\partial E_y}{\partial y} = j \beta E_z
\displaystyle \frac{\partial H_x}{\partial x} + \frac{\partial H_y}{\partial y} = j \beta H_z
E_x = - j \displaystyle \frac{1}{\omega \epsilon} \frac{\partial H_z}{\partial y} + \displaystyle \frac{\beta}{\omega \epsilon} H_y
E_y = - \displaystyle \frac{\beta}{\omega \epsilon} H_x + j \displaystyle \frac{1}{\omega \epsilon} \frac{\partial H_z}{\partial x}
E_z = - j \displaystyle \frac{1}{\omega \epsilon} \frac{\partial H_y}{\partial x} + j \displaystyle \frac{1}{\omega \epsilon} \frac{\partial H_x}{\partial y}
H_x = j \displaystyle \frac{1}{\omega \mu} \frac{\partial E_z}{\partial y} - \displaystyle \frac{\beta}{\omega \mu} E_y
H_y = \displaystyle \frac{\beta}{\omega \mu} E_x - j \displaystyle \frac{1}{\omega \mu} \frac{\partial E_z}{\partial x}
H_z = j \displaystyle \frac{1}{\omega \mu} \frac{\partial E_y}{\partial x} - j \displaystyle \frac{1}{\omega \mu} \frac{\partial E_x}{\partial y}
It should be possible to express the transverse field components as functions of the longitudinal field components:
E_x = E_x (E_z, H_z)
E_y = E_y (E_z, H_z)
H_x = H_x (E_z, H_z)
H_y = H_y (E_z, H_z)
Which is equivalent to state that just two scalar functions E_z = f(x,y)e^{-j \beta z} and H_z = g(x,y)e^{-j \beta z} are actually independent. But how could it be proved? It is not evident from the equations I wrote above: they show instead that E_z, H_z appear to be functions of E_x, E_y, H_x, H_y.
The only link I could find is http://my.ece.ucsb.edu/York/Bobsclass/201B/W01/potentials.pdf: at the bottom of page 11, it shows that all the fields can be expressed in terms of two scalar functions. But it is not a direct approach, because it uses the Hertz Vector potentials.
Is there a direct approach to prove that all the 6 field components are function of just 2 of them?
You chose z as the propagation axis, so the fields along that axis won't behave like those in x and y.
This is reasonable. But why?
Anyway, there is a direct approach to express E_x, E_y, H_x, H_y as functions of E_z, H_z only.
For example, let's combine the first and the fifth equations in order to cancel H_y: we will obtain
E_x = -j \displaystyle \frac{1}{k^2 - \beta^2} \left( \omega \mu \frac{\partial H_z}{\partial y} + \beta \frac{\partial E_z}{\partial x} \right)
Where k^2 = \omega^2 \mu \epsilon. A similar result for E_y can be obtained from equations 2 and 4. The same is for the magnetic field components.
  • · Replies 19 ·
