Induced Emf: Magnet Passes through a Coil
The discussion revolves around the phenomenon of induced electromotive force (emf) as a bar magnet passes through a solenoid. Participants explore the relationship between the orientation of the magnet, the resulting magnetic flux, and the induced emf, as well as how these factors relate to the observed peaks in emf graphs during the experiment.
  • Some participants question why the incoming peak is positive when a north-facing magnet is dropped through the coil, seeking clarification on the relationship between magnetic field, induced magnetic field, and emf.
  • One participant emphasizes the importance of the coil's winding and connection to the voltmeter, suggesting it affects the direction of the induced emf.
  • Another participant expresses confusion about the lab manual's statement that magnetic flux increases when the magnet enters the coil, questioning whether this is always true.
  • Some participants argue that the orientation of the magnet (north vs. south facing) influences whether the peak is positive or negative, indicating that magnetic flux does not simply increase with the magnet's entry.
  • One participant explains the right-hand rule to illustrate how the direction of emf relates to the rate of change of flux, but acknowledges the confusion surrounding the negative sign in the emf equation.
  • There is a suggestion that visualizing the magnetic field lines of the magnet could clarify how the direction of induction varies with the magnet's orientation.
  • Participants note that the direction of the magnet's movement (up or down) also affects the polarity of the induced emf peaks.
Participants express multiple competing views regarding the relationship between the orientation of the magnet, the direction of the induced emf, and the behavior of magnetic flux. The discussion remains unresolved, with no consensus on the implications of the lab manual's statements or the effects of coil winding.
Participants highlight limitations in understanding the relationship between magnetic flux and induced emf, particularly regarding the assumptions made about the direction of flux change and the effects of magnet orientation. There are unresolved questions about how these factors interact during the experiment.
fromthepast
I'm doing a lab write-up for physics 2. The experiment is about the title, a bar magnet being dropped through a solenoid.
I have to explain four graphs that plot the change in emf (y axis) vs. time (x) axis. There are incoming and outgoing peaks on these graphs. I have to tie these results with the equation emf = -N(ΔΦ/Δt).
For example, if a bar magnet is dropped with north facing downward through the center of the coil, why is the incoming peak positive? How do the magnetic field, induced magnetic field, and emf all tie together to produce a positive peak?
Thanks!
How the coil is wound and attached to the voltmeter would make a difference. You should know the right hand rule. Pick a direction, either up or down through the coil. What was the sign of the rate of change of flux through a surface inside the coil that is normal to this direction, as the bar magnet approached the coil?
Now that you know the sign of rate of change of flux for this surface, using the normal vector, the right hand rule, and the emf formula, what was the direction of the emf (if you viewed the coil from the top, would it be clockwise or clounter clockwise)? Now, based on the emf direction and the way the coil is wound, would the wire at one end of the coil have higher or lower voltage than the other end, if a voltmeter was placed across the coil?
The way in which the coil was wound and attached to the voltmeter is irrelevant (for this experiment).
My confusion is this: the lab manual states that when the magnet is entering the coil, the magnetic flux through the coil increases with time. Wouldn't that mean the magnetic flux always increases if it is entering a coil? (But that can't be true).
The negative sign in emf = -N(ΔΦ/Δt) also confuses me.
It's not irrelevant if you care about whether the peaks are positive or negative.
Why do you think that?
Stick your right thumb out and curl your fingers in a loose fist. If the rate of change of flux is positive in the direction the tip of your thumb is pointing, then the emf circles around in the opposite way that your fingers are curling. That is, it would go around like going from the tips of your fingers to your knuckles. The minus sign is due to it being the opposite way (fingertips to knuckles as opposed to knuckles to fingertips).
I don't mean to ignore what you said earlier, but before I can understand that, I need to address this problem:
My lab manual says "When the magnet is entering the coil the magnetic flux through the coil increases with time." How is this possibly true? If north is downward when the magnet enters, the emf makes a positive peak. On the other hand, if south is downward, the peak is is a trough (instead of a crest).
Magnetic flux does not necessarily increase just because the magnet enters. Doesn't it depend on the orientation of the magnet as well?
First of all, you need to visualize the magnetic field of the magnet.
Like you said, a magnet has a north pole and a south pole. Magnetic fields are visualize via closed magnetic lines, these magnetic lines come out of the north pole and go back in through the south pole...then, they travel through the inside of the magnet to come, again, through the north pole...
...you need to draw this, with arrows...
and you will see that when to insert the north pole into the solenoid, the arrows in the magnetic lines will be in opposite directions as compared to when you insert the south pole first...
...according to the right hand rule, the best induction is produced when a wire is crossing magnetic lines that are perpendicular to it...and so, when you introduce a bar magnet into a solenoid, most of the induction is pretty much happening in the turns around the ends of the bar magnet and not much in the ones next to the body of the magnets...again, pay attention to the direction of the magnetic lines...
so the polarity of the peak is relative to the polarity of the magnet (north down vs. south down) and the way the coil wraps around the solenoid?
i.e., a crest could be a trough and a trough could be a crest, in that it all depends on the experiment?
it also depends in which direction the magnet is moving...whether it is going down or up
  • · Replies 194 ·
23K
  • · Replies 42 ·
  • · Replies 20 ·
