Induction Foil Iron vs. Aluminum
The discussion centers on the use of aluminum foil in induction sealing compared to magnetic iron foil. Participants agree that while aluminum is cheaper, its thermal conductance is higher than that of iron, which complicates its heating efficiency in induction processes. The consensus suggests that aluminum's lower magnetic permeability makes it less effective for induction heating, despite its cost advantages. Ultimately, the choice of aluminum over iron in induction applications is primarily driven by economic factors rather than performance efficiency.
  • Understanding of induction heating principles
  • Knowledge of thermal conductance and magnetic permeability
  • Familiarity with materials science, specifically properties of metals
  • Basic concepts of induction sealing technology
  • Research the principles of induction heating and its applications
  • Explore the thermal conductance properties of various metals
  • Investigate the role of magnetic permeability in induction processes
  • Learn about advancements in induction sealing technologies
Engineers, materials scientists, and professionals involved in packaging technology or induction heating applications will benefit from this discussion.
Watson
Hey everyone.
This question revolves around induction/cap sealing - or just induction heating in general.
Does anyone have an idea of why aluminum foil is used in induction sealing vs. using something that is magnetic, such as iron foil? My initial thought is simply aluminum foil being significantly cheaper, but I am curious is someone could answer this from an engineering perspective. Does aluminum foil heat more efficiently than magnetic iron foil?
Thanks guys!
Good question. My initial thought is that aluminum would be much more difficult to heat with induction, as iron typically has a much higher permeability. My money is on the cost.
Mine as well. Aluminum has higher thermal conductance than iron/steel, and as a the foil itself is much smaller than the skin depth of aluminum, the resistance is bumped up significantly. That being said, the skin depth in magnetic iron foil should be similar when you take into account the permeability. Stumped on this one.
  • · Replies 51 ·
