Curiousphy
- 41
- 4
If there's an inductor in series between a lightning rod and the ground rod, how will it affect the lightning protection ability of the system?
The discussion centers on the impact of using an inductor in a lightning protection system, specifically between a lightning rod and a ground rod. It concludes that typical inductors cannot withstand the immense current of a lightning strike, leading to arcing and potential failure. The recommended wire gauge for lightning protection is 2 AWG copper, which is considered the minimum to direct lightning safely. Additionally, the discussion emphasizes that lightning strikes behave more like DC than AC, and proper engineering practices must be followed to ensure effective lightning protection.
PREREQUISITESElectrical engineers, safety professionals, and anyone involved in designing or maintaining lightning protection systems will benefit from this discussion.
What do you think?Curiousphy said:Thank you again. What if it was a resistor instead of an inductor, would it act as an open circuit or cause arcing?
Indeed.gneill said:A lightning strike is more DC than AC, given that it's a sudden discharge of a stored charge.
https://en.wikipedia.org/wiki/Lightning#Transient_currents_during_flash said:Positive lightning strikes tend to be much more intense than their negative counterparts. An average bolt of negative lightning carries an electric current of 30,000 amperes (30 kA), and transfers 15 coulombs of electric charge and 500 megajoules of energy. Large bolts of negative lightning can carry up to 120 kA and 350 coulombs.[39]
30 ohms is not a low series impedance in a lightning conductor, it is a very high impedance and demonstrates poor engineering. I would expect a flash around that impedance as the surrounding air is ionised by the voltage gradient. But you are suggesting that the series impedance is a fault in a lightning conductor and that the lightning strike is 100 metres away, so I ask you why the lightning conductor was not placed in the more exposed position where the strike eventually occurred? A lightning conductor should never be installed below a more attractive conductor.Curiousphy said:… if the grounding path to Earth had a low impedance inductive or resistive load (say 30 ohms) ...
Until you specify the voltage, current, impedance and risetime there can be no sensible answer to your question.Curiousphy said:Are there inductors/resistors that could possibly survive such a surge current?
As it was stated before at that current any lightning conductor has notable resistance and inductance too: to the point that even the shape of the wire matters. Lightning conductors are expected to survive lightning.Curiousphy said:I was curious if there were any man made inductors or resistors able to withstand lightning
You know wrong. As the first line of electronic surge protection there are low impedance (! at least far lower than the load, in those circumstances) devices that offers a path to ground for the incoming high voltage surge and thus limiting the energy/voltage/current passing for the further protection barriers. For a decent protection system there are several lines of defense, all based on the limiting effect of the previous level, all aimed at different power levels.Curiousphy said:I know there are high impedance inductors/resistors designed to block a power surge to protect electronics
