Inductor Energy Loss Calculation
16 replies · 2K views
Tom_Greening
I was so happy with the assistance provide here by NascentOxygen! Great contributor!
I have another question:
A 20V battery is connected to an inductor with 1000μH that has 1000 turns with a cross section area of 1cm^2 is connected for 0.3 Sec during where 20J energy are lost over that period.
Calculate how much flux has accumulated after 0.3 Sec?
This is where I need help. What equation do I start using? I understand it will be an integration with respect to time, but I am not sure where to start
Yes, i figured that. But not sure where to start looking for that.
If possible could you post the equation i need to start using.
so far I understand the 1J = 1A per second. So 20J = 20A per second.
I'm having difficulty associating the Joules in there.
NascentOxygen said:
you first need to represent the situation as an electrical circuit, an equivalent circuit. How will you draw it using all ideal electrical elements?
Drawing it would be a DC supply connected to an inductor via a switch. I've seen many diagrams. I've read there is a small amount of resistance, but I think I should ignore that.
I've seen the formula I = Vb/R * (1-e^-tR/L)
Sometimes it is appropriate to make approximations, or overlook non-idealities, yes. Which element in your equivalent circuit is going to account for the 20 J mentioned?
Something like that could be useful.
The inductor has a work measured in Joules = 1/2Li^2 but I just can't get my head around the time component.
The formula says that the amount of work capacity is capable of inductor, but doesn't allow to incorporate the current in time.
Whatever the current happens to be, that determines the stored energy at that moment.
The inductor stores energy, to release it later. The details about the 20 J uses the word "lost".
Thankyou for the reply, but I'm still lost myself. What do you mean by the very last sentence?
I understand the concept after reading up on inductors that the inductor stores energy where current rises steadily, but due the electromagnetic motive force the inductor is resisting that with an opposing force where increasing current increase in flux. When the supply is disconnected the magnetic field dissappears, discharging and causing energy in the opposite direction.
I've dug up so many formulas but I'm going around in circles with this trying to put it in terms of formula that defines time..
Is it lost as heat then?
I think I have to go back and read more...
I'm reading a book here... energy is lost to the magnetic field...
So would that mean the 20J information is not needed for the overall part of calculations since it is converted to heat?
If electrical energy is continually being lost from the circuit, then the inductor will be storing less energy than it otherwise would be. So you can't ignore this energy loss. You'll have to account for it.
You account for losses by including the inductor's resistance. You cannot pretend it is zero.
