Inelastic collision of two particles
16 replies · 7K views · last reply
toothpaste666
After a completely inelastic collision, two particles of the same mass m and same initial speed v are found to move away together with the speed (2/3)v. Find the angle between the initial velocity vectors of the objects.
It is completely inelastic which means the two objects stick together and share the same final speed. Energy is not conserved but Momentum is so
mv + mv = (m+m)V
2mv = 2m(2v/3)
2mv=4mv/3
2=4/3
I definitely did something wrong here
You need components I am pretty sure, because it is asking for angles. So makes your x components of momentum, and y components of momentum. So what I am saying is that your question asks for an angle, so that they collide at an angle, so you would need two equations one for everything in the y direction, and the other everything in the x direction.
Should there be two different angles I am looking for here or are they equal? Meaning if I put the final velocity vector of the two particles along the x axis, is the angle in between the x-axis and the particle above the x-axis equal to the angle between the x-axis and the particle below the x axis?
So you are kind of on the right track, there is one initial angle θ and for simplicities sake, let's say one of the particles is moving perpendicular to the x axis, and the other is moving at an angle θ from the x axis, and let's say that the new angle formed when they collide is θ'. With this information you should be able to create two different equations, and the mass's and velocities should divide out, then you have two unknowns you could easily solve for.
Hand-drawn vector diagram of a collision: a green arrow labelled v at angle θ meets a red vertical arrow labelled v, and a blue arrow labelled (2/3)v leaves at angle θ' from a horizontal and vertical axis.
Is this an accurate representation of what is going on? (my terrible drawing skills aside) the green and red vectors are the two particles before the collision and the blue one with angle θ' is the two of them moving while stuck together.
  • Hand-drawn vector diagram of an inelastic collision: a green vector v at angle θ and a red vector v meet at a point on black x and y axes, with a blue vector (2/3)v at angle θ' leaving the point.
I am ending up with an equation for the x components:
vcosθ = (4/3)vcosθ'
and for the y components:
vsin + v = (4/3)vsinθ'
for simplicities sake I said, that you can make one of the particles move parallel to the x axis, then this eliminates one of the unknown angles.
Wouldnt that have to assume that the angle between the two starting vectors is 90 degrees?
No it wouldn't, imagine rotating the x and y-axis so that the one particle is moving parallel to the x axis. Instead of two angles, its one.
I think it would be simpler to take the final motion as being along an axis. Given that they have the same mass and initial speed it follows that they made the same angle to the axis on approach,
ok so now I am getting
mvcosθ+mvcos(-θ) = 2/3vm
and
mvsinθ+mvsin(-θ) = 0
I still feel stuck here :[
Their components of velocity in opposite directions (which you made the 'sine component') will balance (or "annihilate") to give zero, but how will the components of velocity parallel to each other affect each other?
Is that correct? On the left, you have units of momentum, on the right, units of velocity. What's missing?
oops! thanks I fixed it. So the m's and v's cancel and it becomes cosθ+cos(-θ) = 2/3
So that means the mass after they collide (and stick together) will only be m? (That's what your math says, is that correct, though?)
Also, what is cos(-θ)? Is there another way to write that?
ok I am sorry i was being sloppy there
mvcosθ+mvcos(-θ) = 2/3v(m+m)
mvcosθ+mvcos(-θ) = 4/3vm
cosθ+cos(-θ) = 4/3
cosθ+cosθ = 4/3
2cosθ = 4/3
cosθ = 4/6
cosθ = 2/3
θ = cos^-1(2/3)
therefore the angle between them two starting vectors is double that?
toothpaste666 said:
θ = cos^-1(2/3)
Yes.
