Modeling a 2-Body Collision with Simulink
The discussion focuses on modeling a 2-body collision using Simulink, specifically addressing inelastic impacts and the relevance of the Modulus of Elasticity. The user seeks to understand how varying material elasticity affects post-impact velocity, given known masses and an initial velocity of 2 m/s for one object. It is established that if the collision is inelastic, the Elastic Modulus is not significant, as deformation beyond the yield point occurs. The user is looking for premade elements in Simulink to accurately model this scenario.
  • Understanding of inelastic and elastic collision theories
  • Familiarity with the Modulus of Elasticity
  • Basic knowledge of Simulink for modeling simulations
  • Concept of mass and velocity in collision dynamics
  • Research the equations governing inelastic collisions
  • Explore Simulink's built-in libraries for collision modeling
  • Learn how to implement the Modulus of Elasticity in simulations
  • Investigate techniques for modeling material deformation in collisions
Engineers, physicists, and simulation specialists interested in modeling collision dynamics and material behavior in Simulink.
alext918
Does anyone know of any inelastic impact / collision equations or theories that somehow incorporate a spring constant or Modulus of Elasticity?
I have a problem where I need to show how changing a different material (ie. a different Elasticity) will affect the velocity after impact.
The masses are known, and one object is moving at 2 m/s right before impact and hits a stationary object.
Thank you
I don't know of any such equation - but would also be interested if one exists.
The reason I doubt the existence of such a formula is that if the Modulus of Elasticity is important in the impact, it is an elastic collision. Or, perhaps putting it a little differently; if the collision is inelastic, then the Elastic Modulus is not going to be very helpful.
For the collision to be inelastic, you need to deform the material beyond its yield point. Beyond this point the Elastic Modulus is not much use.
It is very difficult, I imagine, to meaningfully quantify the behaviour of a material in a collision when it deforms.
As I say, if there is a mathematical treatment, I would also be interested. (And surprised if it could predict the velocities after impact)
So I've found that using modulation and simulation techniques and using the program Simulink can model my problem accurately.
The issue now is that I am new to Simulink and unfamiliar with the program. I must model a 2 body collision in Simulink. Physically, I have an object hitting another object, which both in turn hit a third object.
Does anyone have or know of any premade elements to model a linear (axial), 2 mass collision? I want to couple 2 of these 2 mass collisions to model my problem. Any help is apprceiated.
Thank you!
  • · Replies 19 ·
