Inelastic collision with an inclined plane
7 replies · 5K views · last reply
Vinita
A particle is thrown upward with speed 10√3 m/sec. It strikes an inclined surface. Collision between the particle and inclined plane is perfectly inelastic. What will be the maximum height attained by the particle from the ground.
Diagram of a particle launched from a horizontal ground line into an inclined surface at 45 degrees; the ground segment is labelled 3 m and an upward arrow with 10(3)^0.5 marks the initial velocity.
2. Relevant information and equations
  • In perfectly inelastic collision (e=0) colliding objects stick to each other.
  • When net F external = 0, momentum is conserved.
  • v2 = u2 + 2as (for constant acceleration a)
Just before collision let velocity of particle be v
⇒ v2 = (10√3)2 - 2g(3)
⇒ v = 4√15 m/s (g=10 m/s2
Let m = mass of particle, M = mass of surface, V = velocity of particle and surface along the normal.
Along the normal,
∫Ndt = m(V-vcos45°) = MV
⇒V = mv/√2(m-M)
Since denominator is very large, V≈ 0
Now component of velocity along the inclined plane ( = vsin45°) will not change as the normal reaction (which will give the impulse during collision) is acting to perpendicular to it.
So finally particle will move along the incline particle( upwards) till its velocity becomes zero.
0 = (vsin45°)2 - 2s(gsin45°)
⇒ s = 6√2
Thus, total height above ground = s(sin45°) + 3 = 9 m
But the answer is 6 m.
Is it because I neglected the velocity along the normal?
  • Diagram of a particle launched from a horizontal ground line into an inclined surface at 45 degrees; the ground segment is labelled 3 m and an upward arrow with 10(3)^0.5 marks the initial velocity.
That is only true for head on collisions.
It will move that way immediately after impact, but there is no glue holding it to the ceiling.
But they will still move together along the normal, right? Because velocity of separation = 0
So, will it be like a projectile?
I don't understand how that's possible if the surface and ball are moving together along normal. What does perfectly inelastic collision signify here?
Only at first.
Yes.
That immediately after collision the velocities are the same in the direction of the impulse, so zero in this case.
Gravity continues to act, and its component in the direction of impulse is away from the ceiling, so the particle will separate from it.
haruspex said:
Only at first.
Okay I get it now.
At maximum height, velocity along y-axis = 0
⇒ 0 = (v/2)2 - 2gs
⇒ s = 3 m
Total height above ground = 3 +3 = 6 m
Thanks you for helping me.:smile:
Vinita said:
Okay I get it now.
⇒ 0 = (v/2)2 - 2gs
⇒ s = 3 m
You are welcome.
Just to interject that you really do not need to solve the parabolic motion to solve the problem. You can just equate the difference in potential energy to the loss of the contribution of the y-component of velocity to kinetic energy.
Yeah, I didn't think of that. Thank you.
