Inequalities with trigonometric functions
tigerd12
Three functions are defined as follows:
f:x> cos x for the domain 0< (or equal to) x < (or equal to) 180
g:x> sin x for the domain 0< (or equal to) x < (or equal to) 90
h:x>tan x for the domain p< (or equal to) x < (or equal to) q
Find the range of f.
-1<(or equal to) x < (or equal to) 1 (correct?)
Given that the range of h is the same as the range of g, find a value of p and a value of q.
this is the one i don't quite understand, i got p = 0, q= 90, is that right?
if the domain is the same therefore the range is the same, yes?
No, not necessarily. And, isn't the question "given identical ranges, find the domain of h"?
Yes, so I am right. ?
Can you graph sin and tan between 0 and 360? Or between 0 and 90? What is Sin(0)? What is Sin(90)?
What is Tan(0)? Tan(90)?
A bit peculiar, actually! I assume they mean 180 degrees, and 90 degrees.
Normally, sine and cosine, as functions are interpreted as in radians. The way sine and cosine are defined, as functions, x is "dimensionless" but radians give the correct values. Anyway, I'll go with degrees.
When p= 0, tan(p)= 0. That's not what you want is it?
What is tan(90)? That's also not what you want is it?
For what p is tan(p)= -1?
For what q is tan(q)= 1?
I think I got it
Wait.. I think I got this..
so sin(0) - tan(0
sin(90) = 1
tan(45) = 1
therefore the P and Q are 0 and 45?
so sin(0) - tan(0
sin(90) = 1
tan(45) = 1
I'm sorry, how did we get to talking about sin(x)- tan(x)? I thought the question was about the range of tan(x).
"h:x>tan x for the domain p< (or equal to) x < (or equal to) q" and you were to find the domain given that the range was the same as the range of sin(x) (-1 to 1).
You said you thought the domain would be the same as long as the range was the same. That is certainly not true! Different functions can take different domains (x-value) to the same range (y-value).
Yes, it is true that tan(45)= 1 so the upper limit is 45. But since the lower limit on the range of sin(x) is -1, you need to determine where tan(x)= -1, not 0!
