Can I use the mean value theorem to prove that f>g for all x in (a,b)?
The discussion centers on using the Mean Value Theorem (MVT) to prove that one continuous function, f, is greater than another, g, over an interval (a, b). The initial conditions include that f is greater than g at the limit approaching a and that the derivatives f' and g' are greater than zero throughout the interval. Participants emphasize the need for clarity on assumptions, particularly regarding differentiability and the application of the MVT. A critical point raised is the importance of defining f(a) and g(a) as their right-hand limits at a to utilize the interval correctly. The conversation concludes with a focus on properly applying the MVT to demonstrate the relationship between the functions over the specified interval.
Dank2
Assume f and g are two continuous functions in (a, b).
If at the start of the segment I've shown f>g by taking the lim where x ---> a+ and the f ' > g ' for every x in (a,b )
can i say that f >g for all x in (a,b )? is there a theorem for that? that looks intuitively right.
You need to state more clearly what you are assuming.
You say ##f' > g'## but you only assumed ##f## and ##g## are continuous on ##(a,b)##. Do you mean to assume they are differentiable? And are you saying that ##\lim_{x \to a^+} f(x) > \lim_{x\to a^+}g(x)##? If the answers are yes to these, I suggest you try proving your result using the mean value theorem.
Likes Dank2
Define ##f(a)## and ##g(a)## equal to their right hand limits at ##a## so you can use ##[a,b)## and ##f(a)>g(a)##. Let ##h(x) = f(x) - g(x)##, so you have ##h'(x)>0##. What does the mean value theorem tell you about ##h## if you have a point ##c## in ##(a,b)## where ##f(c)<g(c)##?
Likes Dank2
if f(c)<g(c) then h(c) < 0, doesn't help me much
I asked you what the mean value theorem tells you. Write it down.
That there is point c where the derivative of h'(c) is parallel to the straight line connecting the two end points of the segment
You need to write down the equation the mean value theorem tells you applied to ##h##.
H'(c)= (h(b)-h(a))/b-a > 0
Forget the > 0 for a minute. Examine the sign on the left side versus the sign on the right side.
[Edit, added] I overlooked you haven't used the point c properly on the right side. You don't know anything about h(b). And you don't want c on the left side.
Now that the football game I was watching while I was working with you is over, I will be a bit more explicit about what you are doing wrong. Here is what I suggested in post #5:
Then I asked you to write what the mean value theorem tells you about ##h##. You wrote this:
Dank2 said:
H'(c)= (h(b)-h(a))/(b-a) > 0
There are several things wrong with this besides missing parentheses. First, there is no > 0 in the mean value theorem. Second, you can't use ##c## in ##H'(c)## because I have already used it above where you assume ##c## is a point where ##f(c)<g(c)##. Third, ##f## and ##g## aren't defined at ##b## so neither is ##h(b)##.
What you need to do is apply the mean value theorem to ##h## on the interval ##[a,c]##. Write it out carefully and completely. You will need to use the words "there exists" somewhere in your application of the mean value theorem.
