How can I evaluate this infinite exponential series using a method I can learn?
The infinite series \(\sum_{n=0}^\infty n e^{-n\lambda}\) can be evaluated using differentiation techniques. The series can be transformed into a geometric series, where \(\sum_{n=0}^{\infty} e^{-n\lambda} = \frac{e^{\lambda}}{e^{\lambda}-1}\). By differentiating the geometric series with respect to \(\lambda\) and applying the appropriate transformations, the result is \(\frac{e^{\lambda}}{(e^\lambda-1)^2}\), as confirmed by Wolfram Alpha.
  • Understanding of infinite series and convergence
  • Familiarity with geometric series and their properties
  • Basic knowledge of differentiation techniques in calculus
  • Experience with mathematical software like Wolfram Alpha
  • Study the properties of geometric series in depth
  • Learn about differentiation of series and its applications
  • Explore advanced techniques for evaluating infinite series
  • Practice using Wolfram Alpha for evaluating complex mathematical expressions
Mathematicians, students studying calculus, and anyone interested in evaluating infinite series and applying differentiation techniques.
ShayanJ
Insights Author
I've just encountered the infinite series ## \sum_{n=0}^\infty n e^{-n\lambda} ##. I know that in general its not possible to evaluate an infinite series but because wolframalpha.com could evaluate it(which gave the result ## \frac{e^{\lambda}}{(e^\lambda-1)^2} ##), it seems to me that this one has can be solved by a method that I can learn. So I want to learn it. Any ideas how to do it?
Thanks
Here are the elements of a solution. Some of the justifications must be verified, but here goes:
ne^{-n\lambda}= \frac{d}{d\lambda}(-e^{-n\lambda}). The series e^{-n\lambda}is geometric, with ratio e^{-\lambda}, and thus \sum_{n=0}^{\infty}e^{-n\lambda}=\frac{1}{1-e^{-\lambda}}=\frac{e^{\lambda}}{e^{\lambda}-1}. Change the sign and derive with respect to λ and you are there.
Likes ShayanJ
As shown by this animation, the fibers of the Hopf fibration of the 3-sphere are circles (click on a point on the sphere to visualize the associated fiber). As far as I understand, they never intersect and their union is the 3-sphere itself. I'd be sure whether the circles in the animation are given by stereographic projection of the 3-sphere from a point, say the "equivalent" of the ##S^2## north-pole. Assuming the viewpoint of 3-sphere defined by its embedding in ##\mathbb C^2## as...
  • · Replies 16 ·
