How can we define a limit approaching negative infinity?
The discussion revolves around defining limits as they approach negative infinity, particularly in the context of one-sided limits. Participants explore the transition from definitions involving positive infinity to those involving negative infinity, while also considering the implications of these definitions in various mathematical contexts.
  • Philosophical discussion
  • Some participants present a formal definition for limits approaching positive infinity and seek to derive a corresponding definition for limits approaching negative infinity.
  • There is a discussion about the typical use of different symbols (such as M instead of ε) in the definitions of limits approaching infinity.
  • Concerns are raised about the behavior of the function 1/x as x approaches 0, questioning the applicability of the limit definitions in this case.
  • Some participants express a preference for using absolute values in their definitions and raise philosophical questions about the nature of +∞ and -∞, suggesting that they represent fundamentally different concepts.
  • A participant mentions the Riemann sphere mapping as a perspective from complex analysis, indicating a preference for this approach in understanding limits.
  • There is a debate about the relevance of cardinality in the context of discussing limits and infinity, with some participants arguing that these concepts are distinct.
  • Philosophical reflections on the discussion are noted, with one participant suggesting that certain ideas should be set aside during specific seasons due to personal circumstances.
Participants do not reach a consensus on the definitions of limits approaching negative infinity, and there are multiple competing views regarding the nature of infinity and its implications in limits. The discussion remains unresolved with respect to the philosophical aspects of infinity.
Some definitions and assumptions are not universally accepted, and there are unresolved questions regarding the applicability of limit definitions to specific functions, such as 1/x. The discussion also highlights the potential confusion arising from the use of the term "infinity" in different mathematical contexts.
RubroCP
I have the following definition:
$$ \lim_{x\to p^+}f(x)=+\infty\iff \forall\,\,\varepsilon>0,\,\exists\,\,\delta>0,\,\,\text{with}\,\,p+\delta< b: p< x < p+\delta \implies f(x) > \varepsilon$$
From this, how can I get the definition of
$$\lim_{x\to p^-}=-\infty? $$
The definition says: We can make the values of ##f(x)## arbitrary great around ##x=p^+.## or: There is always a neighborhood of ##p^+## in which the function values become at least as high as we want them to be.
Now, how does this transform to low instead of high?
Thanks, my friend. I will try here again.
The usual definitions don't use ##\epsilon## for this type of limit, but instead use M or some other letter. ##\epsilon## is typically some small number, relatively close to zero.
The definition you have usually goes like this:
$$ \lim_{x\to p^+}f(x)=+\infty\iff \forall M >> 0, \exists \delta > 0, \text{ if } p \lt x \lt p + \delta \text{ then } f(x) > M$$
The definition for the limit being negative infinity is similar.
limx→p+f(x)=+∞⟺∀M>>0,∃δ>0, if p<x<p+δ then f(x)>M
What about the "limit" of 1/x as x tends to 0? There is no interval around 0 where 1/x is >100.
The definition I wrote is for a one-sided limit. For any x in the half-interval (0, .01), 1/x > 100.
OK. I would prefer using absolute values, though. And then there is the philosophical question: Is +∞ different from -∞? Since neither one represents a number, how can we tell?
Since my main background is complex analysis, I prefer the Riemann sphere mapping.
Saying that ##\lim_{x \to x_0} f(x) = \infty## is merely shorthand for saying that the function values get arbitrarily large as x gets nearer to ##x_0##. The function that you listed, f(x) = 1/x, can be made arbitrarily large and positive for positive x near zero, and can be made arbitrarily negative for negative x near zero. Neither limit "exists" in the sense of being a real number, but the infinity symbol conveys the unboundedness of the function values. The two one-sided limits are qualitatively and quantitatively about as different as they could possibly be, so, yes, ##+\infty## and ##-\infty## are very different.
Mark44 said:
The two one-sided limits are qualitatively and quantitatively about as different as they could possibly be, so, yes, +∞ and −∞ are very different.
https://en.wikipedia.org/wiki/Cardinality
Well, spring is here in force and my head is stuffed - some philosophical ideas should really be left undiscussed until pollen season is well and truly over.
The cardinality of an infinite set, and infinity or negative infinity being the value of a limit, are basically totally distinct concepts that happen to share the word infinity. I'm sure there's some theory out there that unites the concepts in a very cool way, but I think for a first pass at learning either concept it's best to totally ignore the other one.
  • · Replies 16 ·
  • · Replies 25 ·
  • · Replies 20 ·
  • · Replies 25 ·
