Vincf
- 25
- 2
- TL;DR
- I consider the infinite scaling limit of an elliptic planar charge distribution and show that the horizontal component of the electric field does not tend to zero.
Hello,
This post is related to my previous discussion about the uniformly charged infinite plane. However, since the example and the approach are quite different, I thought it would be clearer to open a separate thread. I hope this is appropriate, as I am still new to this forum.
The goal is to construct an example closer to a ring decomposition, which several participants seem to prefer. The key point is that the observation point is located at a focus of the ellipse, and I consider a scaling centered at this point.
I am trying to better understand how the infinite plane result emerges as a limit of finite charge distributions.
I consider a planar surface charge distribution (uniform surface density ##\sigma>0##) bounded by an ellipse whose polar equation is
r=\frac{p}{1+e\cos\theta}
where the origin is one focus ##F##. (##p## is the parameter and ##e## the excentricity)
I am interested in the horizontal component of the electric field at the focus, in the plane of the charge distribution. This horizontal component is continuous across the charged sheet, and no convergence issue arises.
The exact calculation is not difficult. However, symmetry considerations and dimensional analysis immediately show that the horizontal field must lie along the major axis, directed toward the other focus, and its magnitude must be of the form
E=\left(\frac{\sigma}{\epsilon_0}\right)f(e)
where ##f(e)## is a function which depends only on the eccentricity ##e##. In particular, ##f(0)=0##. The parameter ##p##, which has dimensions of length, cannot influence the result.
Now consider a scaling centered at the focus. The scaling parameter is ##p##. As the ellipse is scaled indefinitely, the charge distribution expands without bound but the focus ##F## where I compute the horizontal electric field does not move. Since the field does not depend on ##p##, the horizontal component does not tend toward zero (Unless ##e=0##)
Yet in the limit, the charge distribution covers the entire plane.
How can this be reconciled with the classical result that the electric field of an infinite plane has no horizontal component?
