Infinite series- converges or not
4 replies · 3K views
asif zaidi
I have 2 questions I am having problems with.
The goal is to determine if the series converges or not.
Q1: Sum from(1 to inf) of (exp^i)/( (exp^2i) + 9)
I tried to do the integral test but I cannot seem to integrate. Any guides would be appreciated.
Also if I wanted to compare it what would I compare it to.
Q2: Sum from (2 to inf) of 1/( (i^2) - 1)
I did the integral test and came out to the following
integral of 1/i^2 -1 = 1/2 (ln(i-1) - ln(i+1))
So in looking at this as i approaches infinity, can I say that integral approaches 0 and therefore this series converges.
All help is appreciated.
Thanks
Asif
The integral test is indeed a good way to go. Can you show us how you tried to integrate it? Once you do that, I'll point you in the right direction.
The series does converge, but you can do better than the integral test. If you recognize that the series is telescoping, you can actually find its sum.
Dick: thanks for response. I will look at your way. Always good to learn new ways
Tom: This is how I did the integral test
Let u = exp^(2x) + 9
du/dx = 2exp^(2x)
This is where I got stuck. I thought once I do du/dx, I should get e^x in this equation but since I didn't I couldn't get anywhere.
So I tried by integration by parts and went into an infinite loop
a- let u = 1/( exp(2x) + 9)
b- du/dx = -2/(exp(2x +9)
c- let dv = exp^x dx
d- v = e^x
To integrate
uv - integral (v wrt dx)
integral (e^x/e^2x +9) = e^x/(e^2x + 9) +2 integral (e^x/e^2x +9)
Thanks
Asif
You want to let u=exp(x) instead. You will end up with a rational function in u whose antiderivative you should recognize.
