Infinite union and intersection
The discussion focuses on proving the equality between the union of a set A and an infinite collection of sets B_n, and the intersection of A minus those sets. The initial attempt at a solution correctly identifies that if an element x is in the intersection of (A \ B_n) for all n, then x must be in A and not in any B_n. However, the proof requires further elaboration to demonstrate that if x is not in any B_n, it must also be in the union of A and B_n. Additionally, the converse needs to be established: if y is in A union B_n, it cannot be in the intersection of (A \ B_n). Clarification and additional steps are needed to complete the proof effectively.
jasonchen2002
Given a set A \in R^m, B_n \in R^m for n \in N, show that
A \ Union {from n = 1 to inf} B_n = Intersection {from n = 1 to inf} (A \ B_n}
Same equation as above
I think I have a solution in mind, but I wanted to make sure it is correct:
Say, take x \in (Intersection {from n = 1 to inf} (A \ B_n}), in order for x to be in that set, x must be in A \ B_n for all n \in N.
That implies A \ Union {from n = 1 to inf} B_n, is that correct for the proof? Can I somehow write it out better? I hope someone can fill the gaps in the proof, and any help will be appreciated.
How does it imply that? That's the whole point of the proof. Yes, you are right that the fact that x is in A\ B_n for all n means that x is in A. Now you need to show that x is NOT in "union B_n". How does that follow? (I'm not saying it doesn't! I am saying you need to show that.)
Of course, you also need to prove that "if x is in A\ union B_n, then x is in \intersection (A\B_n)".
That's the main trouble, I can't seem to describe the answer...
If x is in A \ B_n for all n, then x is in a set containing A "minus" B_n for all n, but n goes from 1 to infinity, that's the whole set B_n (union), so x is in A "minus" the union of B_n?
As for the other way around, take y \in A \ union B_n, for y to exist there must be at least one B_n for some n \in N such that y is in B_n.
That means the set A does not contain y, but now I'm not sure where to go to show that y is also in the intersecton of (A \ B_n)
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 16 ·
