Infinity subtracted from infinity is undefined.
  • Context: Undergrad
  • Thread starter Thread starter Hippasos
    Infinity
46 replies · 18K views
al-mahed said:
I think as infinity is not a defined amount (you cannot count it)
What do you mean by "amount"? You would be correct to assert that there are no infinite natural numbers, nor are there infinite real numbers.
the ordinary algebra is not applicable
Of course -- different number systems require different arithmetic. e.g. we cannot use natural number arithmetic when working with the cardinal numbers, because natural number arithmetic doesn't tell us anything about infinite cardinals.
(And for completeness, I should point out that we have no a priori reason to asume that natural number arithmetic should coincide with cardinal number arithmetic for finite cardinals. This is a fact that needs to be proven (or assumed) before we can use it)
CRGreathouse said:
Thanks, Hurkyl. Sometimes I wonder if I'm explaining myself poorly... wouldn't be the first time.
It can be hard to explain something new to someone. But it's much harder to explain something to someone who has already seen it, but learned it wrongly. :frown:
Yes, unlearning is hard.
Nice sig, by the way.
I think my english wasn't good enough... I was trying to say that a set with infinite elements cannot be counted in a ordinary fashion
i came across lim x.logx, x --> 0
as equal to 0.
The logx component part would go to - infinity, and that multiplied with a quantity tending to 0 is zero. Does that mean 0 times any quantity (infinite or finite) is always 0?
Slightly off topic, but what's the proof for the sum of two irrational numbers to be irrational?
as equal to 0.
Before I answer your question, please answer mine: why would you think that might mean 0 times an infinite quantity is always 0?
I am getting mightily tired of these "infinity" -threads and what can, or cannot do with them, and that it is somehow strange that some operations remain undefined.
Let us look at the number system consisting of the numbers:
0, 1 and "many"
We let 0 be distinct from 1, and we have relations like 1+1=many, many+1=many and so on.
Numerous undefined relations will naturally occur within such a number system.
as equal to 0.
Sometimes it helps to check if there are trivial counterexamples to what you've claimed. For instance, 1/x^2 tends to infinity as x->0 from the right. x tends to 0 as x->0 from the right. Does the product tend to zero?
For the second question, what is sqrt(2)+(-sqrt(2))? Is it irrational?
I meant besides the trivial case, for irrational sums.
I stand corrected on the 0 times arbitrarily large quantity case.
Thank you.
How about (pi + e + 6) + (-pi - e)? If you want to exclude that case as well, it's going to be impossible to define what "non-trivial" means. I think what you want is that an irrational plus a rational is irrational, which is easy to prove.
Well, it might not be impossible for him to define what he means by "the trivial cases " in a mathematically meaningful way.
Until he does, though, we can't judge whether the sum of two irrationals in his "non-trivial" cases must equal an irrational.
The only way to define "non-trivial" so that his statement is true is that the sum of the two numbers is not a rational, but then it's vacuously true.
Not too sure about that.
It might be that we can separate irrationals into two fairly large classes (by some interesting criterion) and that surprisingly, this criterion would imply, throuygh lengthy proofs, that the sum of two such irrationals necessarily would be irrational.
This could well an important result, but we shouldn't hope for, or expect, its materialization.
Could you be more specific? I have a feeling that's still circular.
by non-trivial i meant 'not using the negative inverse of an irrational to cancel it out in the expression'.
For example sqrt 2 + sqrt 3 is a non trivial case.
How does one prove that
a + b = irrational, whenever a not equal to b, a,b both being irrational.
The irrational number (1 - sqrt 2) is not the additive inverse of sqrt 2. Nor is
[tex]\sqrt{3 - 2 \sqrt{2}}.[/tex]
