Infinity times zero, rotational symmetry
5 replies · 1K views
Happiness
To show that the Lagrangian ##L## is invariant under a rotation of ##\theta##, it is common practice to show that it is invariant under a rotation of ##\delta\theta##, an infinitesimal angle, and then use the fact that a rotation of ##\theta## is a composite of many rotations of ##\delta\theta##. But a rotation of ##\theta## is a composite of an infinite number of rotations of ##\delta\theta##. If ##L## is invariant under a transformation ##R##, is it still invariant under an infinite composite of ##R##?
Is 0 + 0 + ..., added infinitely, or ##\infty\times0## still 0?
If L is invariant under a transformation R, is it still invariant under an infinite composite of R?
Is 0 + 0 + ..., added infinitely, or ∞×0 still 0?
... the second line is not equivalent to the first.
I guess you are thinking that an infinitesimal has zero size, but that is not correct.
The logic goes like this:
If a process leaves an object unchanged, then repeating the process will still leave the object unchanged - it does not matter how many times you repeat the process.
The logic is clear when the process is repeated a finite number of times. But to get ##\theta##, the process must be repeated an infinite number of times.
The Lagrangian ##L## after a transformation ##R = L + \delta L = L + 0 = L##.
The Lagrangian ##L## after a composite transformation ##RR = L + 2(\delta L) = L + 2(0) = L##.
The Lagrangian ##L## after a composite transformation ##RR...R\,(##with an infinite number of ##R) = L + \infty(\delta L) = L + \infty(0) = L##?
Bad notation... infinity is better understood as a limit, not as a number. ie. Evaluate:
$$\lim_{N\to\infty} N(\delta L) : \delta L = 0$$ ... this works because it's defined, while ##\infty(0)## is undefined.
Perhaps if we switch notation a bit:
A process R acting on L would be run in operator notation like ##L' = RL## ...
If L is invarient under R, then ##L'=RL=L##
If we do it again: ##L' = R^2L = RRL = R(RL) = R(L) = L## so we see it is also invarient when the operation is repeated once.
For N (positive integer) operations we write: ##L' = R^N L = R^{N-1}(RL) = \cdots##
If we do it infinite times then we are evaluating: $$L' = \lim_{N\to\infty} R^NL$$
haushofer said:
How do you calculate derivatives explicitly? Aren't you encountering then the same issue?
I believe explicitly it is as follows:
The infinity ##\infty## here is the number of infinitesimal rotation in the composite. It is of order ##\frac{1}{\delta\theta}##. The infinitesimal ##\delta## here is the ##\delta L## under an infinitesimal rotation. It is at most of order ##(\delta\theta)^2##. So in this case, the ##\infty\times\delta## is at most ##\lim_{\delta\theta\rightarrow0}\frac{1}{\delta\theta}(\delta\theta)^2=\lim_{\delta\theta\rightarrow0}\delta\theta=0##.
