Is Infinity x 0 Equal to Zero?
  • Context: High School
  • Thread starter Thread starter Kiki
    Infinity Zero
The discussion revolves around the mathematical expression of infinity multiplied by zero, exploring its implications and interpretations. Participants examine the concept from various angles, including arithmetic rules, limits, and the nature of infinity itself.
  • Some participants argue that infinity times zero is zero, reasoning that adding zero infinitely results in zero.
  • Others contend that standard arithmetic rules do not apply to infinity, suggesting that the expression is indeterminate.
  • One participant introduces the idea that adding a finite value an infinite number of times leads to an infinite result, questioning the initial assumption about infinity times zero.
  • Another participant raises concerns about the nature of infinity, questioning whether different infinities exist and how they might affect the multiplication.
  • Some participants discuss limits, noting that expressions like ##\lim_{x \to \infty} (x \times 1/x)## yield different results, which complicates the understanding of infinity in multiplication.
  • There is a reference to the convergence of infinite series, such as ##\sum_{n = 0}^{\infty}\frac 1 {2^n}##, which challenges the notion that adding finite terms infinitely cannot yield a finite result.
  • One participant emphasizes that multiplication involves numbers and asserts that since infinity is not a number, it cannot be used in multiplication.
Participants do not reach a consensus on the nature of infinity times zero. Multiple competing views remain, with some asserting it is zero, while others argue it is indeterminate or leads to infinite values.
Participants express uncertainty regarding the definitions and implications of infinity, as well as the application of limits in this context. The discussion highlights the complexity and nuances involved in dealing with infinity in mathematical expressions.
Kiki
What is infinity times zero? Isn't it zero? I mean, infinity times zero is the same as zero an infinite amount of times, and adding zero infinitely would give zero because even though zero is always being added, this process is the same as nothing ever being added to zero.
Mathematics news on Phys.org
Simple rules of arithmetic don't apply to infinity, and as such ## \infty \times 0## doesn't mean anything. It's indeterminate.
That leads to all kinds of confusing arguments, what then is ##.0000000000000000000001 \times \infty##? What about ##
\lim_{x \to \infty} (x \times 1/x)##, why is that one in this case?
Adding something that is finite an infinite amount of times would not lead to a finite value, it would lead to an infinite value, so maybe that is the answer to the your first question.
The second question is about limits (which I could use help with), but x/x = 1, so maybe there is no need to consider the variable x as it goes to infinity, so there is no need to consider a limit.
You're still thinking about infinity as an actual amount, it doesn't belong to any of the numbers in which arithmetic depend on. It's a concept. What infinity are we multiplying it by? Is there a difference between the infinity between 3 and 4? or 3.1 and 3.2? Both contain an infinite amount of numbers between them. Would you still reach the same conclusions?
I used limit terms since I assumed that's where you confusion arose. I know I thought similar things back when I started learning limits. ##\lim_{x \to \infty} (x) = \infty##, ##\lim_{x \to \infty} \frac{1}{x}= 0 ##, ## \lim_{x \to \infty} (x \times \frac{1}{x}) = 0 \times \infty = 1## In this case ##0 \times \infty = 1## which is a contradiction to the statement above.
No, this isn't true. Consider ##\sum_{n = 0}^{\infty}\frac 1 {2^n} = 1 + \frac 1 2 + \frac 1 4 + \frac 1 8 + \dots + \frac 1 {2^n} + \dots##. Here we're adding an infinite number of terms, all of which are finite, and it can be shown that these all add up to 2.
What about ##\lim_{n \to \infty}\frac{n - 1}{n + 1}##? It can be shown that this limit is 1, even though ##\frac{n - 1}{n + 1}## is always less than 1 for any finite value of n.
Multiplication is a process involving numbers. Infinity is not a number, so cannot be used in multiplication.
  • · Replies 64 ·
  • · Replies 31 ·
  • · Replies 64 ·
  • · Replies 36 ·
