Initial velocity (and momentum)
In a collision between a 2020kg car moving at 20.0m/s and a 1400kg car at rest, the discussion focuses on demonstrating momentum conservation in a reference frame moving at 10.0m/s in the direction of the moving car. The initial momentum in this frame is calculated as 6200kg*m/s after accounting for the velocities of both cars. The initial velocity of the 1400kg car in the new frame is 10.0m/s in the opposite direction, leading to its momentum being -14000kg*m/s. The final momentum remains at 6200kg*m/s, confirming that momentum is conserved. The conversation emphasizes the importance of adjusting for reference frames in momentum calculations.
shiri
A 2020kg car moving at 20.0m/s collides and locks together with a 1400kg car at rest at a stop sign. Show that momentum is conserved in a reference frame moving at 10.0m/s in the direction of the moving car.
initial momentum
final momentum
I don't understand why that the answer for initial momentum is not 20200 kg*m/s due to a reference frame moving at 10.0m/s in the direction of the moving car. Can anyone help me out here, that will be awesome
In that new reference frame, what's the initial velocity (and momentum) of the 1400 kg car?
was it 10.0m/s and 14000kg*m/s in the opposite direction?
Exactly.
then do I have to sum it together (20200+ (-14000))kg*m/s? and the answer should be 6200kg*m/s for the initial momentum?
That's correct.
is that mean the final momentum is also 6200kg*m/s?
Sure. Momentum is conserved.
thanks Doc Al
  • · Replies 19 ·
