Injective immersion and embedding
  • Context: Graduate
  • Thread starter Thread starter Korybut
The discussion centers on the relationship between injective immersions and embeddings of manifolds, specifically stating that an injectively immersed submanifold M of a manifold S is embedded if and only if M is locally closed in S. The proof involves demonstrating that the immersed topology coincides with the subspace topology using the constant rank theorem and specific charts. A counterexample involving the figure-eight curve illustrates that the original statement in the textbook is incorrect, emphasizing that properness is the real criterion for immersion to be an embedding.
  • Understanding of manifold theory and definitions of injective immersion and embedding.
  • Familiarity with the constant rank theorem in differential topology.
  • Knowledge of topological concepts such as local closedness and subspace topology.
  • Experience with sequences and continuity in the context of manifolds.
  • Study the constant rank theorem in detail to understand its applications in manifold theory.
  • Explore the concept of local closedness and its implications in topology.
  • Research properness in the context of manifold embeddings and immersions.
  • Examine additional counterexamples to theorems in differential topology to deepen understanding.
Mathematicians, particularly those specializing in differential geometry and topology, as well as students seeking to understand the nuances of manifold theory and the conditions for embeddings and immersions.
Korybut
TL;DR
Why local closedness matters?
Hello!
There is a simple line in the textbook.
If ##S## is a manifold, an injectively immersed submanifold ##M## of ##S## is embedded if and only if ##M## is locally closed in ##S##.
Recall the definition. M is locally closed if for each point ##x\in M## there open ##U\subset S## such that ##M\cap U## is closed in ##U##.
Embedding to injective immesion is simple. The opposite direction is hard.
Suppose I have ##N## as source manifold and ##f:N\rightarrow S## is the injective immersion. I need to show that "immersed" topology coincides with subspace topology. In other words: for any open ##V \subset N## I need to show that ##f(V)=M\cap U_V## where ##U## is open in S.
Immersion allows to use constant rank theorem and build chart ##(A,\phi)## with ##\phi : A \rightarrow \mathbb{R}^k## for ##A\subset N##; and chart ##(B,\psi)## with ##\psi: B\rightarrow \mathbb{R}^{n+k}## for ##B\subset S##. In these charts immersion has the form
##\psi \circ f \circ \phi^{-1} :\mathbb{R}^k \rightarrow \mathbb{R}^{n+k}##
##(x_1,...,x_k)\rightarrow (x_1,...,x_k,0,...0)##.
How do I proceed further?
As it happens usually once you post you are full of ideas
I have the following sketch of the proof. Since ##f(N)=M## is locally closed for any point ##x\in M## there is open ##U\subset S## such that ##M\cap U## is closed in ##U##.
By assumption ##f:N\rightarrow S## is continuous. Therefore I define open in ##N## set ##V##
##V:=f^{-1}(U)\subset N##
Also we can consider restriction of ##f##, namely ##f|_V##
##f|_V :V\rightarrow f(N)\cap U##
This map is bijective (since ##f## is assumed injective) and continuous in the direction ##V\rightarrow f(N)\cap U## (by assumption).
Tricky part is to show ##f|_V {}^{-1}## is continuous. I believe this is where that M is locally closed is handy.
Since ##V## and ##M\cap U## are manifolds one consider convergent sequences and prove the continuous property of ##f|_V {}^{-1}## from sequential definition.
Suppose I pick a convergent sequence ##{f(p_n)}\in f(M)\cap U##. Since set ##f(M)\cap U## is closed (in ##U##) it contains all limit points. So
##\lim_{n\rightarrow \infty} f|_V {}^{-1}(f(p_n))=p##
with some ##p## that comes from bijective property of f. I.e. for the limit ##\lim_{n\rightarrow \infty} f(p_n)=\tilde{f}## there should such ##p## that ## \tilde{f}=f(p)##.
Do I use this property of local closedness correctly?
The original statement is false, even though written in a textbook. Counter example is well known actually
Consider the map ##(0,2\pi)\rightarrow \mathbb{R}^2## such that ##t\rightarrow (\sin 2t, \sin t)##. Image of this map is figure-eight, which is closed in ##\mathbb{R}^2##, map itself is injective and immersion however topology of immersion is finer than subspace topology.
Real criterion for immersion to be embedding is the properness.
  • · Replies 36 ·
  • · Replies 20 ·
