Inside Needle-Like Cavity: E Field in Dielectric Using Gauss's Law
  • Thread starter Thread starter jmtome2
    Dielectric
The discussion revolves around the electric field inside a needle-like cavity within a dielectric material, specifically analyzing how the electric field behaves in relation to the polarization of the dielectric and the geometry of the cavity.
  • Participants explore the use of Gauss's law and the concept of polarization in dielectrics. There are questions about the symmetry of the electric field and the implications of uniform versus non-uniform polarization. Some participants suggest calculating the electric field due to a uniformly polarized needle and discuss the relevance of bound charges.
The discussion is ongoing with various interpretations being explored. Some participants have offered guidance on using the superposition principle and the implications of bound surface charges, while others are questioning assumptions about the electric field being zero inside the dielectric.
There are constraints regarding the assumptions of uniform polarization and the geometry of the needle-like cavity. Participants are also considering the implications of the dielectric's properties on the electric field within the cavity.
jmtome2
Holy Dielectric!
A large block of dielectric contains small cavities of various shapes that may be assumed not to disturb appreciably the polarization. Show that, inside a needle-like cavity parallel to P, E is the same as in the dielectric
[tex]\oint_{S}\vec{E}\cdot \vec{da}=\frac{Q_{enc}}{\epsilon_0}[/tex]
Not really sure how to attack this problem...
I can create a Gaussian object inside the dielectic and using Gauss's law...
Taking the Gaussian surface to be cylindrical, i get that [tex]E=\frac{\pi p_{b}}{2\epsilon_0}[/tex], where [tex]p_{b}[/tex] is the bound charge density inside the dielectric.
How would I calculate E inside of the cavity? Same method? Doesn't [tex]p_{b}=0[/tex]?
What makes you think the electric field is cylindrically symmetric? Is the dielectric linear?
Reading your problem statement, I would assume that the polarization [itex]\textbf{P}[/itex] inside the dielectric is approximately uniform, and that the dielectric need not be linear (which means [itex]\textbf{E}[/itex] and [itex]\textbf{D}[/itex] need not be uniform).
I think you'll just want to calculate the electric field due to a uniformly polarized needle with polarization [itex]-\textbf{P}[/itex] and then use thew superposition principle.
So the needle can be treated as a line, length d, say. But Griffiths leave out the discussion of such a line in Ch.4...
You shouldn't need Griffiths to tell you how to calculate such a field...where are the bound charges in such a needle? How large/small of a field would you expect these charges to create and why?
The bound charges exist at the ends of the needle. Treating this as a dipole of ends -q and +q, i get:
still calculating...
nevermind dipole approach seems to messy...
Then again... treating this as a dipole yields...
[tex]V=\frac{\vec{p}\cdot \hat{r}}{4\pi\epsilon_0\cdot r^{2}}[/tex]
and therefore...
[tex]E=\frac{p}{4\pi\epsilon_0\cdot r^{3}}\cdot (2cos(\theta)\cdot \hat{r} + sin(\theta)\cdot \hat{\theta})[/tex]
But for a skinny needle, how much surface area will there be at the ends...will the resulting surface bound charge be large or small?...If the needle is long these charges will be far apart...doesn't that reduce the field even more?
I would say [itex]\textbf{E}_{\text{needle}}\approx0[/itex].:wink:
Makes sense, but seemed like way too easy of an answer x] so now I've got to prove that E is zero in the rest of the dielectric
umm does it make sense that E inside the dielectric is zero? The bound charge density is zero because P is uniform, leaving the bound surface charge.
Bound surface charge is also zero because it only exists at the surface and I'm looking at a gaussian surface inside?
Therefore potential is zero inside the dielectric and so is E?
No you don't.In fact, you should be able to argue that E is much much larger inside the dielectric, than the field of the needle---which is why you can neglect the field of the needle entirely. You only need to use the superposition principle (superimpose a needle of negative polarization onto the slab to create the needle shaped cavity);
[tex]\textbf{E}_{\text{cavity}}=\textbf{E}_{\text{slab}}+\textbf{E}_{\text{needle}}[/tex]
No, the bound surface charge is very large, and doesn't necessarily create a symmetric field; so just because the net flux is zero inside, doesn't mean the field is zero. (Gauss' Law requires symmetry to be useful!)
So I've got to prove that [tex]E_{cavity}=E_{slab}+E_{needle}=E_{no cavity}[/tex] because the original problem statements is that [tex]E_{cavity}=E_{no cavity}[/tex]?
The only way I can see this working is if [tex]\textbf{E}_{\text{cavity}}=\textbf{E}_{\text{slab} }+\textbf{E}_{\text{needle}}[/tex] and [tex]\textbf{E}_{\text{needle}}[/tex] is neglible (say zero), then [tex]\textbf{E}_{\text{slab}}[/tex] is also zero. Therefore, [tex]\textbf{E}_{\text{cavity}}[/tex] is zero.
Giving end result [tex]\textbf{E}_{\text{cavity}}=0=\textbf{E}_{\text{needle}}[/tex]
You need to understand that [itex]\textbf{E}_{\text{cavity}}[/itex] represents the total field inside the cavity; [itex]\textbf{E}_{\text{slab}}[/itex] represents the field inside the cavity, due to just the dielectric slab; and [itex]\textbf{E}_{\text{needle}}[/itex] represents the field inside the cavity due to just a uniformly polarized needle (w/ polarization [itex]-\textbf{P}[/itex])...
[itex]\textbf{E}_{\text{slab}}[/itex] is the electric field from the whole chunk of dielectric??
You tell me...what does the superposition principle say?
  • · Replies 37 ·
13K
  • · Replies 29 ·
  • · Replies 0 ·
