Integral form of the unit step function
ryanwilk
I need to show that the unit step function (\Theta(s) = 0 for s<0, 1 for s>0) can be written as \Theta(s)=\frac{1}{2\pi i} \int_{-\infty}^{\infty} dx \frac{e^{ixs}}{x-i0}.
Firstly, I'm unsure about what "x-i0" actually means. I've looked online and couldn't find anything but if it means "x minus an infinitessimal multiple of i", it kinda works.
There will be a pole in the upper half of the complex plane.
-For s>0, the pole will be contained, with residue e^0 = 1. Then calculating the integral and dividing by 2\pi i will give \Theta(s) = 1 for s>0.
-For s<0, the pole won't be contained so the integral will be zero and \Theta(s) = 0 for s&lt;0.
However, if "x-i0" just means "x", the pole is on the axis and it won't make a difference whether s is less or greater than 0...
You are right, you should actually read
<br /> \Theta(s)= \lim_{\epsilon \downarrow 0} \frac{1}{2\pi i} \int_{-\infty}^{\infty} dx \frac{e^{ixs}}{x-i\epsilon}<br />
(note how the limit is taken from above).
(As a side remark: In theoretical physics this is a very important equation, relating to causality of events).
Oh right, thanks a lot! :smile:
Any one can explain why the pole is not contained in the upper complex plane if s < 0? Thank you!
Well, the pole is the solution of x_0 - i \epsilon = 0, i.e it is at x_0 = i \epsilon.
So if you take the limit from above, where \epsilon &gt; 0, then it is clearly in the top half of the complex plane (i.e. {z in C | Im(z) > 0 }).
You close the curve in counterclockwise direction, so \operatorname{Im}(x) \to +\infty, therefore it encircles the pole.
Thank you!
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
