Integral of 1+sin(x) all over cos(x)^2
  • Thread starter Thread starter Giuseppe
    Integral
The integral of (1 + sin(x)) / cos^2(x) can be approached by separating it into two simpler integrals. This method involves rewriting the fraction as the sum of two fractions, allowing for easier integration of each term. The first term, 1/cos^2(x), is a standard antiderivative, while the second term requires substitution with y = cos(x). This approach effectively simplifies the integration process. Overall, using this method streamlines the calculation of the integral.
Giuseppe
I was wondering what the best way to do this integral was:
Is subsitution the best way?
The easiest way is to write the fraction as the sum of fractions ((a+b)/c = a/c + b/c)) and integrate the first and second terms of the sum separately. One is a basic antiderivative and the other is a simple substitution.
So what hypermorphism means is that you do:
\int {\frac{{1 + \sin x}}{{\cos ^2 x}}} dx = \int {\frac{1}{{\cos ^2 x}}} dx + \int {\frac{{\sin x}}{{\cos ^2 x}}} dx
As he said, the first one is a standard antiderivative, for the second one try y = \cos x
Relativistic Momentum, Mass, and Energy Momentum and mass (...), the classic equations for conserving momentum and energy are not adequate for the analysis of high-speed collisions. (...) The momentum of a particle moving with velocity ##v## is given by $$p=\cfrac{mv}{\sqrt{1-(v^2/c^2)}}\qquad{R-10}$$ ENERGY In relativistic mechanics, as in classic mechanics, the net force on a particle is equal to the time rate of change of the momentum of the particle. Considering one-dimensional...
  • · Replies 29 ·
