Integral of 1/x=ln(x), or
$$\dfrac{x^h-1}{h}=\dfrac{\exp(h\log(x))-1}{h}=\dfrac{1}{h}\left(\sum_{k=0}^\infty \dfrac{h^k\log^k(x)}{k!}-1\right)=\sum_{k=0}^\infty \dfrac{h^k\log^{k+1}(x)}{(k+1)!}$$
then as h goes to zero, only 0^0=1 remains, giving ln(x)
nice.
But are you sure this is the same limit as mine? they converge at different rates...
just realized the same idea will work:
%5E%7B%5Cinfty%20%7D%5Cfrac%7Bm%5E%7B2k%7Dln%5E%7B2k+1%7D%28x%29%7D%7B%282k+1%29%21%7D.gif
then in the limit as m goes to zero, only 0^0=1 remains, giving just the first term, which is also ln(x)
still working on how to calculate error. who knows about this stuff?
Here i graphed
the red line is pointing in the direction of x, the green line is pointing in the direction of y, and blue points in the direction of z.
Sorry if its hard to see.(i used png this time)
But there appears to be a "sweet spot" around x=1. makes sense considering thats ln(1)=0 and you dont even have to take a limit to get that.
But what makes my formula converge faster than the other one?
lurflurf
2,432
132
$$\left(\dfrac{x^m-x^{-m}}{2m}\right)=x^{-m}\left(\dfrac{x^{2m}-1}{2m}\right)$$
hmm... this doesnt really explain convergence rates though
  • #31
lurflurf
2,432
132
you can think of your limit as an average of
$$\dfrac{x^m-1}{m}\\
\text{and }\\
\dfrac{1-x^{-m}}{m}$$
one is and over estimate and one is an under estimate so the average is better than either
this is an example of estimating derivatives
where we have
$$\dfrac{\mathrm{f}(x+h)-\mathrm{f}(x)}{h}\\
\dfrac{\mathrm{f}(x)-\mathrm{f}(x-h)}{h}\\
\dfrac{\mathrm{f}(x+h)-\mathrm{f}(x-h)}{2h}$$
  • #32
\text{and }\\
where we have
ahh that makes sense. Funny how there can be so many interpretations of one thing
So im guessing there must be a way to generalize limit formulas to an arbitrary order?
  • #33
94
I always found the relationship ## \int_1^x \frac{1}{x'}dx'=\ln x ## amazing. Think about it: The area under the function of inverse numbers from 1 to x tells you what exponent you have to use for e to get x. I also always wondered if there is a way to understand this more intuitively.
  • #34
derivative of what?
Is it possible to take a limit and increase its convergence to arbitrary order n? like with numerical differentation/integration?
edit: applied it to the e^x limit:
if
then
i checked one is an overestimation and the other is an underestimation
so a better estimate would be
unfortunately its no where near as elegant as the expression for ln because the radicals cant be combined.
Its funny, i always felt like ln was a "boring" function for some reason. But lately ive got a newfound respect for it.
  • #35
lurflurf
2,432
132
$$\log(x)=\left. \dfrac{d}{dm}x^m\right|_{m=0}=\lim_{h\rightarrow 0}\dfrac{x^{0+h}-x^0}{h}=\lim_{h\rightarrow 0}\dfrac{x^h-1}{h}$$
yes you can increase the order as much as you want. The trouble is unless you do some clever stuff high order approximate differentiation is unstable.
  • #36
yes. I actually use complex step differentation to calculate that yellow normal vector lol its accurate to all displayed decimal places <3
so do you think that given the fourier series method of averaging the right and left limit works, and that a fourier series is basically a sum of exponentials, that would explain why the method of averaging the left and right limit of
lim xm/m
m→0
works?
  • #37
lurflurf
2,432
132
a good trio for e^x under one exponent is
$$(1+h\, x)^{1/h}\\ (1+h\, x+h^2\, x^2)^{1/h}\\ (1+h\, x+h^2\, x^2/2)^{1/h}$$
Related Threads on Integral of 1/x=ln(x), or
  • Last Post
  • Last Post
  • Last Post
29K
  • Last Post
32K
  • Last Post
26K
  • Last Post
  • Last Post
