Why Does the Integral Over a Closed Surface Equal Zero?
The integral over a closed surface \( S \) that bounds a volume \( V \) equals zero, as established by the Divergence Theorem. Specifically, the integral \( \oint_{S} d\vec{S} = 0 \) holds true when considering the vector nature of \( d\vec{S} \) and the properties of the normal vector \( \vec{n} \). The discussion clarifies that while scalar integrals can yield surface area, vector integrals require the dot product with a vector function to maintain validity. The conclusion is that the divergence of the unit normal vector is zero, leading to the integral's result of zero.
  • Understanding of vector calculus, particularly surface integrals.
  • Familiarity with the Divergence Theorem and its applications.
  • Knowledge of normal vectors and their properties in three-dimensional space.
  • Ability to differentiate between scalar and vector fields in integration.
  • Study the Divergence Theorem in detail to understand its implications for closed surfaces.
  • Learn about vector fields and their properties, focusing on surface integrals.
  • Explore Stokes' Theorem and its relationship to line and surface integrals.
  • Practice problems involving the integration of vector fields over closed surfaces.
Students and professionals in mathematics, physics, and engineering who are working with vector calculus, particularly those dealing with surface integrals and theorems related to flux and divergence.
meteorologist1
I've been stuck on the following problem: If S is a closed surface that bounds the volume V, prove that: integral over this surface dS = 0.
I've been reading several textbooks that discuss flux, Stokes' Theorem, Divergence Theorem, but I can't seem to relate them to the problem I'm doing. The examples in the text all have a vector F and present the integral: integral over a surface of F dS, which I understand it as the flux. Is my case a flux problem? There is no vector F given in my problem.
Should I divide the closed surface into two halves and argue that pairs of normal vectors, one from each half cancel and therefore the integral over this surface dS = 0? What about Stokes' Theorem -- transforming it into a line integral?
Thanks.
\oint\oint_{\partial \Omega} dS=\oint\oint_{\partial\Omega} \vec{n}\cdot \vec{n} dS=\int\int\int_{\Omega} (\nabla\cdot \vec{n}) dV=\int\int\int_{\Omega} 0 dV=0
Okay??I made use of the fact that
\vec{n}\cdot\vec{n}=n^{2}\cos 0=n^{2}=1
,as unitvectors of the exterior normal to the surface.
Because this unit vector is constant (the director cosines are constants),its flux is zero,because its divergence is zero.
Daniel.
Thanks. Actually there's a slight problem: I forgot to tell you that the dS is a vector in my problem. Yours is a scalar. I'm not sure what the difference here is between integrating a scalar and integrating a vector. I don't think the first equality holds anymore for vector dS. Sorry for the confusion. Thanks for your help.
(Show that: \oint_{S} d\vec{S}=0)
Then perhaps it would be a good idea to tell us what the problem really is! You can integrate dS alone (getting surface area) but you can't integrate \vec{dS} alone over a surface: you integrate the its dot product with some vector function.
In dextercioby's \oint\oint_{\partial\Omega} \vec{n}\cdot \vec{n} dS,
\vec{n}dS IS the vector \vec{dS}.
meteorologist:
It seems to me that you want the VECTOR result:
\int_{S}d\vec{S}=\int_{S}\vec{n}dS=\vec{0}
This is achieved as follows:
\vec{n}=(\vec{i}\cdot\vec{n})\vec{i}+(\vec{j}\cdot\vec{n})\vec{j}+(\vec{k}\cdot\vec{n})\vec{k}
So that we have:
\int_{S}\vec{n}dS=\int_{S}(\vec{i}\cdot\vec{n})dS\vec{i}+\int_{S}(\vec{j}\cdot\vec{n})dS\vec{j}+\int_{S}(\vec{k}\cdot\vec{n})dS\vec{k}
since the unit vectors \vec{i},\vec{j},\vec{k} are constants you may take out of the integral.
Use the normal form of the divergence theorem to get your result.
Thanks. I was looking for the vector result, but it was also helpful to know how the scalar result is proved. I wasn't paying attention to dS as a vector or a scalar when I was first posting it, so sorry once again for the confusion.
Glad to be of assistance; welcome to PF!
how do you prove this?
Prove that \int\int_{S} n dS = 0
for any closed surface S.
