Integral of e^2x/(1+e^x) after substitution
  • Level: Undergrad
  • Thread starter Thread starter Sparky_
    Integration
13 replies · 3K views · last reply
Sparky_
Greetings -
This integral is part of a larger problem I'm working on - I'm stuck (I Think)
Here's the integral:
[tex]= \int -\frac{e^{-x}}{e^{-3x}(1+e^x)}dx[/tex]
I've tried some algebra and substitutions:
[tex]= \int -\frac{e^{2x}}{(1+e^x)}dx[/tex]
[tex]= u=e^x[/tex]
[tex]= du=e^x dx[/tex]
[tex]= \int -\frac{u}{(1+u)}du[/tex]
Is this correct? Is this a standard form for something? - looking like ln()?
OR
could go:
[tex]= \int -\frac{1}{e^{-2x} +e^{-x}}dx[/tex]
Split it in two partial fractions
[tex]\frac{u}{1+u}=\frac{u+1-1}{1+u}=1-\frac{1}{1+u}[/tex]
Thanks - I'm still trying to hack my way around to correctly post the problem - I'm trying to find examples of this [tex]stuff, I can't quite get the problem to post correctly.[/tex]
So my integral is
[tex]\int du -\int \frac{1}{1+u} du[/tex]
I know there will be a ln() involved eventually
Here's what I'm getting - can you confirm?
[tex]-e^x + ln|1+e^x|[/tex]
Correct!
Only you forgot an overall minus sign, one from the inital integral!
oops
thanks
By the way, can you suggest any other method that would have solved this integral?
I have not used partial fractions in a long time, if you had not suggested it, I would not have gone there.
The integral looked simple enough for me to "pencil and paper" it and impress my friends without the need for a CRC handbook or other aid - I was wrong.
But this is the more efficient way! To try to transform integrals with log's, sin's, cos's, exp's to rational form, and then apply partial fractions!
At least that' s the way I think! :smile:
Well you could have used polynomial division if you had not thought of adding +/- 1 to the numerator so that you could split it into two.
I guess I need to knock off the rust and practice up a little bit so the next time it's more obvious.
Thank you all for helping with this -
Instead of using partial fractions. Just use another substitution. Use say t=1+u. This implies that u=t-1. So you have integral of (t-1)/t. And keep in mind that dt=du so this integral is relatively easy. Because its just the integral of 1-(1/t). which is t-ln(t). Just back sub for the t. so 1+u-ln(1+u)
