Integral of Gaussian function, for squared x
5 replies · 4K views
Avinto
I am trying to compute an integral, as part of the expected value formula (using a Gaussian PDF)
[tex]\int_{-∞}^{∞} (x)^2 p(x) dx[/tex]
Where p(x) is the Gaussian probability density function:
[tex]\frac{1}{\sigma \sqrt(2 \pi)} \exp(\frac{-x^2}{2 \sigma^2})[/tex]
My aim after this is to be able to compute for all even x^n in the above formula. For all odd x^n, the positive and negative componets cancel out, with an computation of zero for all odd functions.
Wikipedia lists two equations that relate to this:
[1]https://en.wikipedia.org/wiki/List_of_integrals_of_Gaussian_functions
[1]
[tex]\int_{-∞}^{∞} (x)^2 \phi(x)^n dx = \frac{1}{\sqrt(n^3 (2 \pi)^{n-1})}[/tex]
and
[2]https://en.wikipedia.org/wiki/List_of_integrals_of_exponential_functions
[2]
The range here is zero to infinity, however as this function is even, the result for minus infinity to infinity should be twice what the below computes.
[tex]\int_{0}^{∞} (x)^n \exp(-\alpha x^2) dx= \frac{(2 k -1)!}{2^{k+1} \alpha^k} \sqrt(\frac{\pi}{\alpha})[/tex]
Where
[tex]n=2 k, k integer, \alpha > 0[/tex]
Using [1], I can compute a answer equalling 1, which is apparently the right answer. However when using [2] (where k=1), I compute a different anwser:
Compute:
Let [tex]\alpha = \frac{1}{2 \sigma^2}[/tex]
and
[tex]k=1[/tex]
then:
[tex]\int_{0}^{∞} (x)^2 \exp(-\alpha x^2) dx = \frac{(2 k -1)!}{2^{k+1} \alpha^k} \sqrt(\frac{\pi}{\alpha})[/tex]
[tex]=\frac{1!}{4 \alpha}\sqrt(\frac{\pi}{\alpha})[/tex]
[tex]=\frac{\sigma^2}{2}\sqrt(2 \sigma^2 \pi)[/tex]
[tex]=\frac{\sigma^2}{2} \sigma \sqrt(2 \pi)[/tex]
[tex]=\frac{\sigma^3 \sqrt(2 \pi)}{2}[/tex]
Now, this is where I think I messed up. I previously removed
[tex]\frac{1}{\sigma \sqrt(2 \pi)}[/tex]
from inside the integral, and attempted to multiply it by the obtained result (and then doubled everything, as it is an even function)
[tex]2 \frac{1}{\sigma \sqrt(2 \pi)} \frac{\sigma^3 \sqrt(2 \pi)}{2}[/tex]
Then by cancelling:
[tex]=\sigma[/tex]
I'm thinking this is because I took part of the PDF out of the integral, and then changed the limits. However, I'm not sure how to go about working this out while leaving it in there.
I will keep browsing around for a solution to this problem (and the more general x^n), and would really appreciate any hints on this.
Thanks.
[1]
and
[2]
Where
Compute:
and
[tex]k=1[/tex]
then:
Then by cancelling:
[tex]=\sigma[/tex]
Thanks.
First get
[tex]I_n = \int_0^{\infty} x^n \phi(x) \, dx, \:\: \phi(x) = <br /> \frac{1}{\sqrt{2 \pi}} e^{-x^2/2},[/tex]
then obtain the general result by re-scaling the variable. Note that ##x \phi(x) \, dx = d(-\phi(x))## so we can use integration by parts:
[tex]\int x^n \phi(x) \, dx = \int u dv,\\<br /> u = x^{n-1}, \: dv = x \phi(x) \, dx = d(-\phi(x))[/tex]
Thank you for your suggestions.
Ray, I will attempt to work it out using your way later today, and see how it goes.
Orodruin, I have had a go at your method, but have not had much luck.
[tex]t = x^2[/tex]
[tex]\Gamma(z) = \int_0^{∞} t^{z-1} exp(-t) dt[/tex]
[tex]\Gamma(3) = \int_0^{∞} t^{3-1} \exp(-t) dt[/tex]
[tex]\Gamma(3) = (3-1)! = 2[/tex]
Then for the range [itex]{-∞,0}[/itex], this answer should be the same, so I get an answer of 4 overall.I'm working under the assumption that the answer should be 1
Well, the answer cannot be 1. It should be the variance of the distribution (since the expectation value is zero). In fact, you had it (almost) right in your first post... Also note that in the substitution, z is not 3. If you do it correctly, z should have a half-integer value (which is why you end up with a semi-factorial and 2^(k+1)).
Edit: Well, of course the answer would be one if the variance is ... :)
Ok, I see what you mean about the variance, the definition of [itex]\phi[/itex] on the wiki page assumes [itex]\sigma=1[/itex]. Using [itex]\sigma=1[/itex], my calculation did evaluate to one, which is where I must have gotten that assumption from.
I redid my calculations with including [itex]\sigma[/itex], and realized I made a silly error in my cancellation.
Should evaluate to [itex]\sigma^2[/itex], not [itex]\sigma[/itex].
I will look more into the Gamma function as well, and try to understand it from that direction. Thanks
