Is a Function with One Discontinuity Still Integrable on a Closed Interval?
The discussion confirms that a function \( f \) bounded on the closed interval \([a,b]\) and continuous at all points except for a single discontinuity \( x_0 \) within \((a,b)\) is integrable on \([a,b]\). The proof involves utilizing the Riemann integral definition and considering the continuity of \( f \) on the subintervals \([a,x_0]\) and \([x_0,b]\). The boundedness of \( f \) ensures that the area under the curve can be approximated effectively, even with a discontinuity present.
  • Understanding of Riemann integrals
  • Knowledge of continuity and discontinuity in functions
  • Familiarity with bounded functions
  • Concept of subintervals in integration
  • Study the Riemann integral definition in detail
  • Explore the oscillation definition of continuity
  • Learn how to handle multiple discontinuities in integrable functions
  • Investigate the properties of bounded functions and their implications for integration
Mathematics students, educators, and anyone studying real analysis, particularly those focusing on integration and continuity concepts.
ptolema
suppose that f is bounded on [a,b] and that f is continuous at each point in [a,b] with the exception of x0 in (a,b). prove that f is integrable on [a,b].
f is continuous on [a,x0] and [x0,b]
intuitively, i know that this is true because i can envision a hole or jump discontinuity and still find the area under f. still, the theoretical approach is daunting. how do i approximate the area for the regions [a,x0] and [x0,b]. is it enough to say that for some subinterval containing x0, the area is approx. 0?
ptolema said:
Is it enough to say that for some subinterval containing x0, the area is approx. 0?
It's probably not enough to say this if you are to be truly rigorous. However, this is the intuition. As subintervals surrounding x0 become smaller and smaller, the area of some rectangle gets smaller. But what area exactly? And why is it important that f is bounded?
To start answering these questions rigorously, you need to go back to your definition of the integral (I assume the Riemann integral?). At first, it may seem daunting, but if you think about it for awhile, I hope that you'll become so familiar with the ideas/definitions that you won't feel overwhelmed.
If you use the oscillation definition of continuity it might make this problem easier
or you could show ∫abf(x)dx = ∫ax0f(x)dx + ∫x0bf(x)dx fairly easily too I suppose by breaking it into two cases of the type of discontinuity possible in a bound set. The other method is better though, since it could much more easily be generalized to sets with multiple discontinuities.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 23 ·
