Integrate cos(sqrt(5t)) from x to 6
  • Thread starter Thread starter Calculus!
    Integrate
The discussion focuses on integrating the function cos(sqrt(5t)) from a lower bound of x to an upper bound of 6, with participants suggesting a u substitution where u^2 = 5t. There is confusion regarding the integration process and how to handle the bounds, particularly with x as the lower limit. The importance of understanding the Fundamental Theorem of Calculus (FTOC) is emphasized, noting the difference in outcomes when x is the lower versus upper limit. Participants clarify that the integral's evaluation involves finding the derivative of the integral function. Overall, the conversation highlights the complexities of integration and the need for clarity in applying calculus principles.
Calculus!
Here's the question:
integrate the function cos(sqrt(5t)) with lower bound: x and Upper bound: 6
Do a u substitution and then integrate by parts.
but how?
Should i integrate cos (sqrt(5t)) to 10/3 sin t ^3/2?
Calculus! said:
but how?
That's completely wrong. If you differentiate (10/3)*sin(t^(3/2)) you don't anything like
cos(sqrt(5t)). Try the substitution u^2=5t.
would du=5/2u?
because i did
u^2 = 5t
2udu = 5
du = 5/2u
What you want to find is dt in terms of du. u^2=5t -> 2u*du=5*dt. dt=(2/5)*u*du.
Thanks that is helpful, but i do not know how to apply it. Do you think you can walk me through the problem? I feel I have to see it before I can do it.
You are doing fine. Use the substitution to write cos(sqrt(5t))*dt completely in terms of u. It's not that hard.
i am just confused because the lower bound is x. I usually deal with the upper bound being x. Does this change the problem?
would i get 2/5 u cos(sqrt(5t)) integrated from 6 to x ? do i change cos to sin?
Uhhhhh. Your question is making me think that you didn't post the full problem. You want the DERIVATIVE of the integral, right? Not the integral.
If you actually want the derivative of that, pretend you know how to integrate it. So you have an F(t) such that F'(t)=cos(sqrt(5t)). By the FTOC, the integral is F(6)-F(x), right? What's the derivative of that? There is a difference between having x in the upper limit and the lower. Do you see what it is?
