Integrate dy/dx=0 and arbitrary constant?
The integration of the equation dy/dx = 0 results in y being a constant, specifically y = C, where C represents the constant of integration. The discussion clarifies that while the integral of 0 is indeed 0, it is essential to include the constant of integration when integrating both sides of the equation. Failure to do so may result in a loss of marks in academic settings. The participants emphasize that every antiderivative of a constant function includes an arbitrary constant.
  • Understanding of basic calculus concepts, specifically integration.
  • Familiarity with the concept of the constant of integration.
  • Knowledge of differential equations and their solutions.
  • Ability to manipulate algebraic expressions involving constants.
  • Study the properties of integrals, particularly the constant of integration.
  • Learn about differential equations and their general solutions.
  • Explore examples of integrating constant functions in calculus.
  • Review the implications of omitting the constant of integration in mathematical proofs.
Students of calculus, mathematics educators, and anyone seeking to deepen their understanding of integration and differential equations.
DryRun
Integrate:
\frac{dy}{dx}=0
The attempt at a solution
\int \frac{dy}{dx}=\int 0\,.dx
The answer is: y=0 or y=0+A?
This is the part which is confusing, as i know that integral of 0 is 0, but do i have to add a constant of integration??
How about a dy/dx which is as positive as negative over the interval, that could be zero. fix it was e.g. sin(x)
But yeah, a constant.
Now that i think about it, here is a simple example:
Let y=5
\frac{dy}{dx}=0
Now, if i integrate 0, then i should normally get 5. So, the constant of integration has to be involved.
sharks said:
Integrate:
\frac{dy}{dx}=0
The above should be
\int \frac{dy}{dx}~dx=\int 0\,.dx
You are integrating both sides of the original equation, with respect to x.
Zero is merely one antiderivative of 0.
A simpler approach is as follows.
Since dy/dx = 0, then y must be a constant. IOW y ##\equiv## C.
Also, when you integrate both sides of an equation, there is a constant of integration for each side. So the integration that you did would look like this:
y + C1 = 0 + C2
Of course, you can subtract C1 from both sides to end up with y = C, where C = C2 - C1.
Thank you for the clarification, Mark44. :smile:
Most teachers will mark off on homework or a test if you do not include the "constant of integration". If F(x) is an anti- derivative of f(x)- that is, if F'(x)= f(x), then \int f(x)dx= F(x)+ C where C can be any number.
  • · Replies 105 ·
