Integrate sqrt ( 4 -x^2)dx
  • Level: Undergrad
  • Thread starter Thread starter Naeem
    Integrate
24 replies · 141K views
Naeem
Hi,
Can anyone help me integrate :
Integral sqrt ( 4 - x^2) dx
Some ideas:
Make a subsitution x2 = cos (theta)
Taking the derivative of both sides:
2x = - sin (theta).d(theta)
or...
Double angle identity:
(Cosx)^2 = 1 + cos2x / 2
Can anybody give some ideas.
Trigonometrically: x = 2cos(theta), or 2sin(theta), not [tex]x^2 = 2cos(theta)[/tex]
You can't use the double angle identity without making that substitution, so its not really 'or' is it :)
You might be able to do it by parts with u = sqrt(4-x^2) and dv = dx.
By parts will work.
[tex]\int udv = uv - \int{vdu}[/tex]
Let u = [itex]\sqrt{4-x^2}[/itex]
And du = [tex]\frac{2x}{2\sqrt{4-x^2}}[/tex]
Let dv = dx
And v = x
[tex]\int \sqrt{4-x^2}dx = x\sqrt{4-x^2} - \int\frac{2x^2}{2\sqrt{4-x^2}}dx[/tex]
Hope that helps.
I don't see any reason for a double angle. If you factor out that 4 you get
[tex]\sqrt{4- x^2}= 2\sqrt{1- \frac{x^2}{4}[/tex]. And anytime you see something like that you should think "[tex]\sqrt{1- cos^2x}= sin x[/tex]" (or "[tex]\sqrt{1- sin^2x}= cos x[/tex]").
Let [tex]cos(\theta)= \frac{x}{2}[/tex] or [2 cos(\theta)= x[/tex] so that
[tex]-2sin(\theta)dx= dx[/tex]. Then [tex]\integral \sqrt{4-x^2}dx= 2\integral \sqrt{1- (\frac{x}{2})^2}dx= -4\integral\sqrt{1- cos^2\theta}sin \theta d\theta= -4\integral sin^2 \theta d\theta[/tex].
That last integral you can do using [tex]sin^2 \theta= \frac{1}{2}(1- cos \theta)[/tex].
Well, by golly, you do need a double angle!
Jameson said:
By parts will work.
And du = [tex]\frac{2x}{2\sqrt{4-x^2}}[/tex] $
Let dv = dx
And v = x
Hope that helps.
U missed a "-" (=minus) when computing the marked differential.Not to mention the "dx".
Daniel.
You're right. The "dx's" aren't as critical as the minus was... here's the corrected integral.
And du = [tex]\frac{-2x}{2\sqrt{4-x^2}}dx[/tex]
Let dv = dx
And v = x
[tex]\int \sqrt{4-x^2}dx = x\sqrt{4-x^2} + \int\frac{x^2}{\sqrt{4-x^2}}dx[/tex]
Apparently u forgot about it,again.It should have been
[tex](...)+\int \frac{x^{2}}{\sqrt{4-x^{2}}} \ dx[/tex]
,where the 2-s got simplified through.
Daniel.
Oh, alright. Sorry I didn't see it before. I didn't catch what you were referring to. I'll edit my previous post... hope I get it right this time.
I did this problem using Halls of Ivy idea, i.e substitution, and I got
Integral sqrt( 4 -x^2)dx = -2 Integral ( 1-cos ( theta ) dtheta =
= -2[ Integral dtheta - Integral cos(theta)dtheta ]
= -2 ( theta - sin (theta) + C
= -2 ( cos-1 (x/2) - sin ... what do I put theta as here)...
You know that [tex]\sin{\theta}=\sqrt{1-\cos^2{\theta}}[/tex], right? Does that help?
then. theta for the second part would be
theta = arcsin sqrt ( 1- x^2/4)...
[tex]\int \sqrt{4-x^2}dx[/tex]
[tex]u = \sqrt{4-x^2}, du = \frac{-x}{\sqrt{4-x^2}}dx, v = x, dv = dx[/tex]
x = 2sin(t)
dx = 2cos(t) dt
The integral on the RHS becomes:
[tex]\int \frac{8cos(t)sin^2(t)}{\sqrt{4-4sin^2(t)}}dt = \int \frac{8cos(t)sin^2(t)}{2\sqrt{cos^2(t)}}dt = \int \frac{8cos(t)sin^2(t)}{2cos(t)}}dt = 4\int{sin^2(t)}{dt}[/tex]
From there use the trig identity[tex]sin^2(t) = \frac{1-2cos(t)}{2}[/tex]
[tex]2\int{1-cos(2t)}{dt} = 2t - 2\int{cos2t}{dt} = 2t - sin(2t)[/tex]
From x = 2sin(t), t = arcsin(x/2).
[tex]2(arcsin(x/2)-sin(2))[/tex]
Since sin(2) is constant it can be omitted and
[tex]\int \sqrt{4-x^2}dx = x\sqrt{4-x^2} + 2arcsin(x/2)[/tex]
When I evaluate the integral on the LHS on maple it tells me that the first term on the RHS should be divided by 2.
Can anyone figure this out?
Maple is correct (up to a constant he never considers :wink:).
[tex]\int \sqrt{4-x^{2}} \ dx =2 \arcsin\left(\frac{x}{2}\right)+2\frac{x}{2}\sqrt{1-\left(\frac{x}{2}\right)^{2}} + C =2 \arcsin\left(\frac{x}{2}\right)+\frac{1}{2}x\sqrt{4-x^{2}} + C[/tex]
Daniel.
So you square the 1/2 and put it inside making it 1-(x/2)^2. But why does it still have 4 - x^2?
You lost me.
Well,when reversing the substitution u end up with
[tex]2\frac{x}{2}\sqrt{1-\left(\frac{x}{2}\right)^{2}}[/tex]
which used to stand for [itex]\sin 2u =2 \sin u \ \cos u [/tex]<br /> <br /> U know algebra,so how about work that square & square roots...?<br /> <br /> Daniel.[/itex]
The fact that there are different ways of doing a problem does not mean that any of them is wrong!
The original problem was Integral sqrt ( 4 - x^2) dx [tex]\integral \sqrt{4-x^2}dx[/tex]
Let [tex]2 sin(\theta)= x[/tex] so that 2 cos(\theta)= dx. [tex]\sqrt{4- x^2}= \sqrt{4- 4sin^2(\theta)}= 2 cos(\theta)[/tex]. The integral becomes [tex]4 \int cos^2(\theta)d\theta= 2 \int (1+ cos(2\theta))d\theta = 2\theta+ sin(2\theta)[/tex].
Now, go back to x.
No, it's fine.
Here:
[tex]\int \sqrt{4-x^2} \ dx = \int -2\sin \theta \sqrt{4 - 4\cos^2 \theta} \ dx = -4 \int \sin^2 \theta \ dx = -2\int 1 - \cos 2\theta \ d\theta = -2\theta + \sin 2\theta + C = -2\arccos \left( \frac{x}{2} \right) + 2\sin \theta \cos \theta+C[/tex]
[tex]= \frac{x}{2}\sqrt{4-x^2} - 2\arccos \left( \frac{x}{2} \right)+C[/tex]
this is an equivalent answer (it differs only from those above by a constant). Note that here [itex]2\cos \theta = x[/itex].
Here's another way to do it,if u have the patience (:-p).A mathematician should.
Make the obvious substitution
[tex]\frac{x}{2}=\tanh u[/tex]
and go from there...
Daniel.
x = 2sin(t)
dx = 2cos(t) dt
at the very end, how come sin2t becomes a sin2?
If you substitute t=arcsin(x/2) into sin2t, don't we get sin(2arcsin(x/2))?
how could that come out to be sin2?
Can someone please help me? THX!
