Integrate this equation by parts
  • Thread starter Thread starter Xetman
    Integrate parts
The discussion focuses on the integration of the function e^t * t dt using integration by parts. The correct method involves setting u = t and dv = e^t dt, leading to the solution uv - ∫v du = t e^t - ∫e^t dt = t e^t - e^t + C. The alternative method proposed by a participant, where u = e^t and dv = t dt, complicates the integral unnecessarily. Key insights include the importance of choosing the right terms to differentiate and integrate to simplify the integral.
  • Understanding of integration by parts
  • Familiarity with basic calculus concepts
  • Knowledge of exponential functions and their properties
  • Ability to manipulate integrals and derivatives
  • Practice integration by parts with different functions
  • Learn about the reduction formulas for integrals involving polynomials and exponentials
  • Explore the concept of choosing u and dv effectively in integration problems
  • Study advanced integration techniques such as integration by substitution and trigonometric integrals
Students learning calculus, particularly those studying integration techniques, as well as educators seeking to explain integration by parts effectively.
Xetman
Integrate ettdt using integration by parts.2. The attempt at a solution
Seems like a very easy problem; however, I just started learning integration by parts-- didn't understand this.
So the book's method:
u=t dv=etdt
du=dt v= et
uv-∫vdu=tet-∫etdt=tet-et+C.My method:
u=et dv=tdt
du=etdt v=t2/2uv-∫vdu=ett2/2-∫(t2/2)etdt
My method seems wrong, so can anyone please answer me why my method won't work?
Is it just about assigning the correct values to the correct variables?
Your method is not wrong, but it is not helpful. Integration by parts offers several options. We want to replace our integral by a simpler one. Your integral is more complicated. ∫te^t dt can be traded for ∫t^2 e^t dt or ∫e^t dt, the former is worse the latter better. As you practice you will see what choice improves the situation and what does not.
can you please explain how ? I'm confused..
Hi MrWarlock616! :smile:
tet is in two parts, t and et
you can push et up, and t down …
then et stays as et, and t becomes 1, then 0​
of you can push et down, and t up …
then et stays as et, and t becomes t2/2, then t3/6, then …​
the idea is to push in the direction that makes one of them disappear :wink:
This must a new concept. I'm not familiar with the push up and down..but thanks!
The thing to keep in mind is that for elementary integration by parts problems, the tricky term is the integral one is left with. From the original integrand (which is the product of two terms), one term gets differentiated, while the other term gets integrated. Do that in your head, and if the product between the two resulting terms can now be integrated again more easily, then it's the right approach.
Writing it out makes it seem more complicated than it is! :biggrin:
The pushing "up and down" means "integrating and differentiating," respectively. I imagine tiny_tim was thinking of "pushing down" the degree of the "t" part of the original integrand, and the resulting integral (the v du part) would simply be et, as opposed to the one you got using your method.
  • · Replies 16 ·
  • · Replies 22 ·
