Integrate Without Expanding Numerator
  • Context:
  • Thread starter Thread starter paulmdrdo1
    Expanding Integrate
9 replies · 2K views
paulmdrdo1
how to solve this without expanding the numerator.
$\displaystyle \int\frac{(x-1)^3}{x^2}dx$
Not sure if this counts as cheating or not, but I'd say contract the numerator instead! (Bandit)
Substitute $$y=1-x\,$$ $$\Rightarrow$$$$\int\frac{(x-1)^3}{x^2}\,dx=-\int\frac{y^3}{(1-y)^2}\,dy$$Full solution...
$$\frac{d}{dy}\frac{1}{(1-y)}=-\frac{1}{(1-y)^2}$$
$$\Rightarrow$$
$$\frac{y^3}{(1-y)}-3\int\frac{y^2}{(1-y)}
\,dy=$$
$$\frac{y^3}{(1-y)}-3\left[-y^2\log(1-y)+2\int y\log(1-y)\,dy\right]=$$
$$\frac{y^3}{(1-y)}+3y^2\log(1-y)-6\int y\log(1-y)\,dy$$For that last integral, use the same substitution as before to obtain
$$\int y\log(1-y)\,dy=-\int (1-y)\log y\,dy=-\frac{1}{y}+\int y\log y\,dy= $$
$$-\frac{1}{y}+\frac{y^2}{2}\log y-\frac{1}{2}\int y\,dy=$$
$$-\frac{1}{y}+\frac{y^2}{2}\log y-\frac{y^2}{4}$$
The final answer is then
$$\frac{y^3}{(1-y)}+3y^2\log(1-y)-6\left(-\frac{1}{y}+\frac{y^2}{2}\log y-\frac{y^2}{4}\right)=$$
$$\frac{y^3}{(1-y)}+3y^2\log(1-y)+\frac{6}{y}-3y^2\log y+\frac{3y^2}{2}$$
no, your answer doesn't match the answer in my book.
I haven't checked this myself but did you remember to back-substitute $x$ in for $y$? His final answer is in terms of $y$ but he made the initial substitution $y=1-x$.
However, that doesn't make the one above incorrect. What form is given in your book? ;)
the answer is in terms of x when expanding the numerator.
OK, so here was my solution...
$$\Rightarrow$$
\,dy=$$
In the line just above that last one, the terms on the RHS encased in large brackets have already been back-substituted, so now I'll do the other bit:$$\frac{y^3}{(1-y)}+3y^2\log(1-y)-6\left(-\frac{1}{y}+\frac{y^2}{2}\log y-\frac{y^2}{4}\right)=$$$$\to$$$$\frac{(1-y)^3}{y}+3(1-y)^2\log y-6\left(-\frac{1}{y}+\frac{y^2}{2}\log y-\frac{y^2}{4}\right)=$$$$\frac{(1-y)^3}{y}+3(1-y)^2\log y+\frac{6}{y}-3y^2\log y+\frac{3y^2}{2}$$Also, y is a dummy variable here, much like your x, so the answer above is identical to
$$\frac{(1-x)^3}{x}+3(1-x)^2\log x+\frac{6}{x}-3x^2\log x+\frac{3x^2}{2}$$
Does that match your book?
i tried to solve this by expanding the numerator of the integrand,
$\displaystyle\int\frac{(x-1)^3}{x^2}dx = \int \frac{(x^3-3x^2+3x-1)}{x^2}dx = \int\frac{x^3}{x^2}dx-3\int\frac{x^2}{x^2}dx+3\int\frac{x}{x^2}dx-\int\frac{dx}{x^2}$...
...$\displaystyle\int xdx-3\int dx+3\int\frac{1}{x}dx-\int\frac{dx}{x^2} = \frac{x^2}{2}-3x+3ln(x)+\frac{1}{x}+C$
I don't know what the book says, but yours is not correct.
This one is correct.
-Dan
I decided to just keep applying integration by parts until it wasn't needed anymore (i.e. three times):
First time: $u=(x-1)^3$, $dv=\dfrac{1}{x^2}\,dx \implies \,du=3(x-1)^2\,dx$ and $v=-\dfrac{1}{x}$.
Thus,
\[\int\frac{(x-1)^3}{x^2}\,dx = -\frac{(x-1)^3}{x} + 3\color{red}{\int\frac{(x-1)^2}{x}\,dx}\]
Second time: $u=(x-1)^2$, $dv = \dfrac{1}{x}\,dx\implies \,du=2(x-1)\,dx = (2x-2) \,dx$ and $v=\ln x$.
Thus,
\[\color{red}{\int\frac{(x-1)^2}{x}\,dx} = (x-1)^2\ln x - \int (2x-2)\ln x\,dx\]
and hence
\[\int\frac{(x-1)^3}{x^2}\,dx = -\frac{(x-1)^3}{x} + 3(x-1)^2\ln x - 3\color{blue}{\int(2x-2)\ln x\,dx}\]
Third time: $u=\ln x$, $dv = (2x-2)\,dx \implies \,du=\dfrac{1}{x}\,dx$ and $v=x^2-2x$.
Thus,
\[\begin{aligned}\color{blue}{\int(2x-2)\ln x \,dx} &= (x^2-2x)\ln x - \int \frac{x^2-2x}{x}\,dx\\ &= (x^2-2x)\ln x - \int x-2 \,dx \\ &= (x^2-2x)\ln x - \frac{x^2}{2} + 2x + C\end{aligned}\]
Therefore, by not expanding the numerator, we get
\[\int\frac{(x-1)^3}{x^2}\,dx = -\frac{(x-1)^3}{x} + 3(x-1)^2\ln x - 3(x^2-2x)\ln x + \frac{3}{2}x^2 -6x+C\]
