Integrating e^(2 theta)sin(9 theta) d theta
  • Thread starter Thread starter tangibleLime
    Integrating Theta
The integral of e^(2θ)sin(9θ) dθ can be solved using integration by parts (IBP). The process involves selecting u = e^(2θ) and v = -1/9 cos(9θ), leading to a recursive integration by parts. The final result is expressed as ∫ e^(2θ)sin(9θ) dθ = (9/11)(-1/9 cos(9θ)e^(2θ) + 2/81 sin(9θ)e^(2θ)) + C. Despite the correct method, the solution was marked wrong, indicating a possible arithmetic error in simplification.
  • Integration by Parts (IBP) technique
  • Understanding of exponential and trigonometric functions
  • Ability to differentiate integrals
  • Familiarity with algebraic simplification
  • Review advanced Integration by Parts techniques
  • Practice solving integrals involving products of exponential and trigonometric functions
  • Learn how to verify integrals using differentiation
  • Explore common pitfalls in algebraic simplification
Students studying calculus, particularly those focusing on integration techniques, and anyone looking to improve their skills in solving complex integrals involving exponential and trigonometric functions.
tangibleLime
Integrate.
\int e^{2\theta}sin(9\theta) d\theta​
\int udv = uv - \int vdu​
I started out with integration by parts (IPB).
u = e^{2\theta}
du = 2e^{2\theta} d\theta
v = \frac{-1}{9}cos(9\theta)
dv = sin(9\theta) d\theta
uv - \int vdu = -\frac{1}{9}cos(9\theta)*e^{2\theta}+\frac{2}{9}\int cos(9\theta) d\theta​
Noticing that the new integral on the right is just about the same as how I started (sin just turned into cos), I did IPB once again.
u = e^{2\theta}
v = \frac{1}{9}sin(9\theta}
dv = cos(9\theta) d\theta
uv - \int vdu = \frac{1}{9}sin(9\theta)*e^{2\theta}-\frac{2}{9}\int sin(9\theta)*e^{2\theta} d\theta​
Combining all of this into the equation so far...
-\frac{1}{9}cos(9\theta)*e^{2\theta}+\frac{2}{81}sin(9\theta)*e^{2\theta}-\frac{2}{9}\int sin(9\theta)*e^{2\theta} d\theta​
Noticing that this new integral on the right is the exactly equal to what I started with, I added it to both sides in order to remove it from the right side. I mentally noted that the left version could have a coefficient of \frac{9}{9}, and added the right side's coefficient of \frac{2}{9} to give me the final coefficient for the left version of \frac{11}{9}.
\frac{11}{9}\int e^{2\theta}sin(9\theta) d\theta = -\frac{1}{9}cos(9\theta)e^{2\theta}+\frac{2}{81}sin(9\theta)e^{2\theta}​
To get that \frac{11}{9}\ out of the left side of the equation to get my original integral back, I multiplied both sides by it's reciprocal, \frac{9}{11}. Then I tacked on the constant of integration to arrive at my final answer.
\int e^{2\theta}sin(9\theta) d\theta = \frac{9}{11}(-\frac{1}{9}cos(9\theta)e^{2\theta}+\frac{2}{81}sin(9\theta)e^{2\theta}) + C
This was marked wrong, even after I simplified the answer (which I did not do here, but I checked the simplification with WolframAlpha). Any suggestions?​
If you differentiate your result, you get 85/99 e2tsin 9t, which is almost what you started with, so it looks like you just made an arithmetic or algebra error somewhere. Your method is correct.
Thanks, I figured as much, that's usually my downfall :D As long as I know my method is correct, I'm okay with it.
  • · Replies 19 ·
