Integrating expression with two Abs terms
7 replies · 3K views
Baggio
Hi,
I'm trying to integrate an expression I derived from multiplying the Fourier transform of two Lorentzians together. The expression is
[tex]\int^{\infty}_{-\infty}{dt.e^{-|t + \tau +a| - |t-a|}[/tex]
How do you go about solving this? I tried splitting it up but you have two different values of t where a sign change occurs...
Any help would be appreciated :)
Identify all points at which the exponent changes sign. Suppose you found 4 points t1 - t4. (I made it up). Then integrate over (-infinity, t1], (t1, t2], (t2, t3], (t3, +infinity) separately.
I can't seem to get it... I always end up with just a single point where a sign change occurs
Hi,
I tried with the followign example
[tex]\int^{\infty}_{-\infty}{dt.e^{-|t + 5| - |t|}[/tex]
And I get [tex]1+5e^{-5}[/tex]
I ran tried evaluating it in maple and it says the answer is [tex]6e^{-5}[/tex]
I don't see what I'm doing wrong I integrated from -inf to -5/2 then -5/2 to +5/2 then 5/2 to inf.
I also tried with -inf-> -5/2 and -5/2 -> inf and this just gave me 1
With a = 0 and [itex]\tau[/itex] = 5, the plot of -|t + 5| - |t| is increasing for t < -5, constant at -5 for -5 < t < 0, then decreasing for t > 0. So you have 3 regions.
Yep thanks for that managed to work it out... It's easy to see the limits when you plot it out.
Though what if you have something like
and where tau and 'a' can take any real value -ve or +ve
