Integrating Inverse Powers: Solving ∫1/∛(x^2) dx
  • Thread starter Thread starter priscilla98
    Integral
11 replies · 2K views
priscilla98
Evaluate the given integral::
∫1/∛(x^2 ) dx
∫(x^2)^-1/3 (1) dx
1/2 ∫(x^2)^-1/3 (2) dx
But somehow I'm stuck here. I know this is an easy problem but I just can't figure it out. Any help is appreciated. Thanks a lot
Please any help is appreciated. Am i right so far?
∫1/∛(x^2 ) dx
∫(x^2)^-1/3 (1) dx
I can't tell what's going on. You might want to use latex. Is the problem:
[tex]\int \frac{1}{x^{2/3}}dx[/tex] ?
You're right that the function you have is x-2/3.
Remember that when differentiating a function of the form xn, you get the result:
nxn-1
In other words, the procedure for differentiation is
1. multiply the expression by a factor equal to the exponent
2. subtract 1 from the exponent
Therefore, the procedure for integrating a power function is to reverse these steps. In other words do the exact opposite steps in the exact opposite order:
1. Add 1 to the exponent
2. Divide the expression by this new exponent
If you started with xn, you end up with:
[ 1/(n+1) ]xn+1
You know that this procedure works, because if you apply it to your differentiated expression nxn-1, you get back what you started with:
(n/n)xn = xn
I'm sorry. The problem states to evaluate the given integral which is
1 / 3√x^2 dx
nxn-1
[ 1/(n+1) ]xn+1
(n/n)xn = xn
[tex]\int[/tex] [tex]\frac{1}{3\sqrt[]{x}^{2}}[/tex]
This is the integral, thanks a lot
It's the third root.
gb7nash said:
Is that the third root or 3 times the square root?
You can see from the original post that it is clearly supposed to be the third root. Let's not complicate the issue. It is not necessary for the OP to learn LaTeX just for this thread.
priscilla98:
Try typing out a solution in plain text using the steps I provided. It's all just exponents, multiplying and dividing, so you can just use ^ * and / like you were before. Or you can try using the buttons marked X2 and X2 above the reply text box in order to get superscripts and subscripts.
[tex]\int[/tex] [tex]\frac{1}{\3sqrt[]{x}^{2}[/tex]
Here's a few definitions and rules that may be useful since I'm not sure you already know these:
[tex]\sqrt[3]{x} = x^{\frac 1 3}[/tex]
[tex]\frac 1 x = x^{-1}[/tex]
[tex](x^2)^{\frac 1 3}=x^{2 \cdot \frac 1 3}=x^{\frac 2 3}[/tex]
[tex]\frac 1 {\sqrt[3](x^2)} = \frac 1 {(x^2)^{\frac 1 3}} = \frac 1 {x^{2 \cdot \frac 1 3}} = \frac 1 {x^{\frac 2 3}} = x^{-\frac 2 3}[/tex]
