Integrating partial derivatives in a field equation
17 replies · 3K views · last reply
Samson Ogaga Ojako
I am integrating the below:
\begin{equation}
\psi(r,v)=\int \left( \frac{\frac{\partial M(r,v)}{\partial r}}{r-2M(r,v)}\right)dr
\end{equation}
I am trying to write ψ in terms of M.
Please, any assistance will be appreciated.​
Astronomy news on Phys.org
Is it good enough to write ##\psi## in terms of ##M## and ##\int \frac{M}{r^2}dr##?
If yes then just write ##\psi=\int ((\frac{\partial M}{\partial r}\frac{1}{r}-\frac{M}{r^2})+\frac{M}{r^2}-2M)dr## and notice that the first term is the derivative of ##\frac{M}{r}## so after all it will be $$\psi=\frac{M}{r}-2\int Mdr+\int \frac{M}{r^2}dr+C$$
Is r a radius? (Or any other dimensionsl quantity?) If so, where did this integral come from?
The 'r' is a shell radius while the "v" is the time.
The question is related to spacetime.
Thank you for getting in touch
This looks so good enough, Sir.
I must say, thank you very much.
Let me look at how you were able to simplify the integration first.
This is brilliant.
I will get back to you just now.
Cheers
This does not answer where your integral came from. The reason I am asking is that if ##r## is dimensionful, then your expression is dimensionally inconsistent because ##(\partial M/\partial r)/r## does not have the same physical dimension as ##M##.
Maybe there is some sort of constant (with the proper units) in front of the ##-2M## term, which he omitted.
See the attached for details of how \psi, #M# and #r# are related.
Best regard.
So you have not transcribed the problem correctly then. The integrand is
\frac{\partial_r M}{r - 2M},
not
\frac{\partial_r M}{r} - 2M.
I think he is unable to see the typing clearly because of the way the question is typed.
So, I've decided to attach a copy of the typed question to him for a better understanding of the question.
Thank you once again.
Cheers
not
Yeah
Delta² said:
Ah, then what I did in post # 2 is not correct...
Oh ok.
You can take a second look at it again while I retype the question in LaTeX.
Cheers
Well this look like some sort of assignment or homework. You have to show us some effort from your side.
All I can think right now is to transform the integral so that we get as end result ##-\frac{1}{2}\ln|r-2M|+\frac{1}{2}\int \frac{1}{r-2M} dr +C##
Delta² said:
Well this looks like some sort of assignment or homework. You have to show us some effort from your side.
It is not really a homework or assignment. This is part of my research finding. I've gotten to a stage where I have 3 field equations with 3 variables #M#, #\psi# and #phi# all are functions of #(r,v)#
\begin{equation}
\frac{\partial {m}}{\partial v} = 4\pi{r^{2}}\phi_{v} \left[e^{-\psi}\phi_{v} + \left( 1-\frac{2m}{r}\right) \phi_{r} \right] = m^{\prime}(v)
\end{equation}
\begin{equation}
\frac{\partial {\psi}}{\partial r} = 4\pi{r^{2}}\phi_{r}^2 = \psi^{\prime}(r)
\end{equation}
\begin{equation}
\frac{\partial {m}}{\partial r} = 2\pi{r^{2}}\phi_{r}^2 \left( 1-\frac{2m}{r}\right) = m^{\prime}(r)
\end{equation}
From equations 2 and 3, I was able to get what I shared online.
\begin{equation}
\end{equation}.
I have made some effort to get #\psi# in terms of #M# so that I can solve equation 1.
Please, you can help if you can.
Can you have a look again at your equations (3) and (4) , because from those two I get that
$$\psi=\int \frac {2r\frac{\partial M}{\partial r}}{r-2M}dr$$
Oh ok.
Let me check again then.
Oh ok.
You are right Sir
