Integrating sqrt(10z - z^2) using Trigonometric Substitution
  • Thread starter Thread starter stunner5000pt
    Integration
The discussion focuses on integrating the expression \(\sqrt{10z - z^2}\) using trigonometric substitution. Participants suggest substituting \(z = 10 \sin^2 \theta\) and \(z = 5 + 5 \cos t\) to simplify the integral. The integration process involves transforming the expression into a more manageable form, ultimately leading to the integral of \(\cos^2 \theta\). The final steps include applying the identity \(\cos 2\theta = 2\cos^2 \theta - 1\) to complete the integration.
  • Understanding of trigonometric identities, specifically \(\cos 2\theta\)
  • Familiarity with integration techniques, including trigonometric substitution
  • Knowledge of basic calculus concepts, such as integrals and derivatives
  • Ability to manipulate algebraic expressions involving square roots
  • Study the method of trigonometric substitution in integration
  • Learn how to apply the identity \(\cos 2\theta = 2\cos^2 \theta - 1\) in integrals
  • Explore alternative substitution techniques for integrals, such as \(z = 10 - t\)
  • Practice integrating similar expressions involving square roots and polynomial terms
Students and educators in calculus, mathematicians focusing on integration techniques, and anyone seeking to deepen their understanding of trigonometric substitution in integral calculus.
stunner5000pt
trying to integrate \sqrt{10z-z^2}
i have been advised to used trig subsitution wherein i subsitute z = cos theta
however i end up at a dead end
\int \sqrt{10 \cos \theta - \cos^2 \theta} sin \theta d \theta
i could certainly replace the sin
\int \sqrt{10 \cos \theta - \cos^2 \theta} \sqrt{1- \cos^2 \theta} d \theta
hwat now do i expand?
or do i use parts?
alternatively i can use z = 10 sin^2 \theta
i am currenttly working o ntaht because i made a mistake... z should be cos theta
is that hter ight way to go??
\int \sqrt{100 sin^2 \theta - 100 \sin^4 \theta} (20 sin \theta cos \theta) dz
try z=10-w substitution
The simplest choice is to rewrite your root expression as:
\sqrt{10z-z^{2}}=5\sqrt{1-(\frac{z-5}{5})^{2}}
10z-z^2=5^2-(z-5)^2
Try z-5=5\cos{t}
what's more simple than this?
I = \int \sqrt{10z-z^2} dz
z=10-t,~dz=-dt
I= - \int (10-t) \sqrt{10-(10-t)} dt
I= -10 \int t^{ \frac{1}{2}} dt + \int t^{ \frac{3}{2}} dt
arildno, can you explain your solution?
z=10-t,~dz=-dt
Last line isn't correct. it should be I= - \int \sqrt{t (10-t)} dt
It's the same as Yegor's, since we now make the substitution
\frac{z-5}{5}=\cos(t)
I see, well with yegor's/arildno proposal, I end up with 25 \int cos^{2} \theta d \theta
.. then just use \cos 2\theta = 2\cos^{2} \theta - 1, presumably.
  • · Replies 21 ·
