Integrating the Cartesian form of Coulomb's law
This discussion focuses on integrating Coulomb's law in Cartesian coordinates to calculate the potential energy between two opposite charges, specifically in the context of a dipole. The user initially attempts to derive the potential energy using the force equation in Cartesian form, leading to an expression that includes an unexpected factor of three. The conversation highlights the importance of defining a proper path for the integral, emphasizing the need to consider path segments along the x, y, and z axes for accurate calculations. The final potential energy expression derived is U = (3e²)/(4πε₀r).
  • Understanding of Coulomb's law and its applications
  • Familiarity with vector calculus and dot products
  • Knowledge of path integrals in physics
  • Proficiency in Cartesian coordinate systems
  • Study the derivation of potential energy using path integrals in electrostatics
  • Learn about the implications of integrating vector fields in Cartesian coordinates
  • Explore the differences between polar and Cartesian forms of Coulomb's law
  • Investigate the role of path selection in calculating integrals in physics
Physicists, engineering students, and anyone studying electrostatics or vector calculus who seeks to understand the integration of forces in Cartesian coordinates.
haaj86
Hi, I want to calculate the potential energy between two opposite charges (a dipole) and I know how to integrate Coulomb’s law in the polar form, i.e. in terms of “r”
\[<br /> U=\int\mathbf{F}d\mathbf{r}=-\frac{e^{2}}{4\pi\epsilon_{0}}\int\frac{1}{\mathbf{r^{2}}}d\mathbf{r}=\frac{e^{2}}{4\pi\epsilon_{0}}\frac{1}{r}\]
But I want to know how to integrate it when it’s in the Cartesian form i.e.
\[<br /> F(x,y,z)=\frac{qQ}{4\pi\epsilon_{0}}\frac{1}{[x^{2}+y^{2}+z^{2}]^{\frac{3}{2}}}\left(\begin{array}{c}<br /> x\\<br /> y\\<br /> z\end{array}\right)\]
Please I need this urgently, and I’m more interested on how to do the integral because I need this for a much more complicated problem that involves moving charges but if I can’t do it for the stationary charges then I can’t do it for that problem. Please I don’t want anybody to suggest integrating the force in the polar form and then changing the variables to Cartesian because as I said I need to know how to do the integral.
Exactly where are you stuck? Can you expand the dot product \vec F \cdot d \vec r in Cartesian coordinates?
Thanks jtbell, good hint, I stupidly forgot that it's a dot product.
But I have another problem now and this is what I got
\[<br /> U=\int\mathbf{F}.\mathbf{dr}\]<br /> and in the cartesian form we have \[<br /> \mathbf{r}=x\mathbf{\hat{x}}+y\mathbf{\hat{y}}+z\mathbf{\hat{z}}\]
\[<br /> \mathbf{\hat{r}}=\frac{x\mathbf{\hat{x}}+y\mathbf{\hat{y}}+z\mathbf{\hat{z}}}{[x^{2}+y^{2}+z^{2}]^{1/2}}\]
\[<br /> d\mathbf{r}=dx\mathbf{\hat{x}}+dy\mathbf{\hat{y}}+dz\mathbf{\hat{z}}\]<br /> Therefore \[<br /> U=-\frac{e^{2}}{4\pi\epsilon_{0}}\int\frac{1}{[x^{2}+y^{2}+z^{2}]^{3/2}}(x\mathbf{\hat{x}}+y\mathbf{\hat{y}}+z\mathbf{\hat{z}}).(dx\mathbf{\hat{x}}+dy\mathbf{\hat{y}}+dz\mathbf{\hat{z}})\]
\[<br /> U=-\frac{e^{2}}{4\pi\epsilon_{0}}\{\int\frac{xdx}{[x^{2}+y^{2}+z^{2}]^{3/2}}+\int\frac{ydy}{[x^{2}+y^{2}+z^{2}]^{3/2}}+\int\frac{zdz}{[x^{2}+y^{2}+z^{2}]^{3/2}}\}\]
\[<br /> U=-\frac{e^{2}}{4\pi\epsilon_{0}}\{-\frac{1}{[x^{2}+y^{2}+z^{2}]^{1/2}}-\frac{1}{[x^{2}+y^{2}+z^{2}]^{1/2}}-\frac{1}{[x^{2}+y^{2}+z^{2}]^{1/2}}\}\]
\[<br /> U=\frac{e^{2}}{4\pi\epsilon_{0}}\frac{3}{[x^{2}+y^{2}+z^{2}]^{1/2}}=\frac{3e^{2}}{4\pi\epsilon_{0}}\frac{1}{r}\]
So there is an extra 3 in comparison with polar form shown in my first post.
Where did I go wrong?
This is a path integral:
U = - \int_{{\vec r}_0}^{\vec r_{final}}{\vec F \cdot d \vec r}
so you have to pick a starting point {\vec r}_0 at infinity, then set up a path from that point to the point where you want the potential energy. (Imagine holding one charge fixed at the origin and moving the other charge in from infinity along that path.) Then integrate along that path.
You're using Cartesian coordinates, so path integrals are easier to do if they're made of segments along or parallel to the x, y and z axes.
For example, you could start at (x, y, z) = (+\infty, 0, 0) and set up a path to (x_{final}, y_{final}, z_{final}) with three straight-line segments. You pick the segments!
Simply integrating the x, y and z integrals from \infty to x_{final}, \infty to y_{final}, and \infty to z_{final} respectively, doesn't define a proper path. I've been groping unsuccesfully for a way to put the reason why into words...
not so much as a thank you?
  • · Replies 19 ·
