Integrating the Unsolvable: $\int x^xdx$
  • Context: Graduate
  • Thread starter Thread starter airkapp
    Integrating
The discussion revolves around the integration of the function \( \int x^x \, dx \). Participants explore various approaches to this problem, including Taylor series expansion, the Risch Algorithm, and the nature of the integral in relation to elementary functions. The conversation includes both theoretical and practical considerations regarding the existence and form of the integral.
  • Some participants suggest that the integral cannot be expressed in terms of elementary functions, while others propose that it can be approached using Taylor series expansion.
  • One participant mentions that the integral is continuous and thus exists, countering the claim that it does not exist.
  • Another participant references the Risch Algorithm as a method to show that the integral cannot be expressed in elementary terms, although they admit uncertainty about the algorithm itself.
  • Some participants discuss the limitations of using Taylor series centered at 0 due to the function's definition issues in that region, suggesting alternative centers for the series.
  • There is mention of a mathematician named Liouville and a specific condition under which certain integrals are elementary, with a belief that this can be modified to show \( \int x^x \, dx \) is not elementary.
  • A compendium of properties related to the integral is referenced, indicating ongoing exploration of its characteristics.
Participants generally do not reach a consensus on the nature of the integral. While some agree that it cannot be expressed in elementary terms, others propose methods to explore its properties and existence, leading to multiple competing views.
Limitations include the dependence on definitions of elementary functions and the unresolved nature of mathematical steps regarding the Risch Algorithm and Taylor series applications.
airkapp
[tex]\int x^xdx[/tex]
After calculus today, our professor casually asked us to integrate the above problem. Most of us stated DNE (does not exist), or possibly x+1 / x+1 . He stated that both of these solutions were incorrect and than challenged us to write a paper on the subject which seemed ridiculous to me but here I am.
So a few questions...
Can this be done by Taylor Series expansion??
[tex]\int x^x dx=x + \frac{\left( -1 + 2\,\log (x) \right) \, x^2}{4} + \frac{\left( 2 - 6\,\log (x) + 9\,{\log (x)}^2 \right) \,x^3}{54} + \frac{\left( -3 + 12\,\log (x) - 24\,{\log (x)}^2 + 32\,{\log (x)}^3 \right) \,x^4}{768} + \frac{\left( 24 - 120\,\log (x) + 300\,{\log (x)}^2 - 500\,{\log (x)}^3 + 625\,{\log (x)}^4 \right) \,x^5}{75000} + \frac{\left( -5 + 30\,\log (x) - 90\,{\log (x)}^2 + 180\,{\log (x)}^3 - 270\,{\log (x)}^4 + 324\,{\log (x)}^5 \right) \,x^6}{233280} + {O(x^7)[/tex]
or is the answer simply dF/dx is x^x ?
I've seen this many times, the last time someone jokingly asked me to solve it, to which the answer was solve you xxxxxxx :smile:
I asked a friend about this very thing and he said in fact the only way it can be done is with an infinite Taylor Expansion.
So there really is no "solution", and all maths programs I've tried won't solve it.
Nor will pen and paper.
[itex]\int e^xdx=e^x+C[/itex]
Same deal here basically, the solution is either non "renormalizable" or itself.
There is no integral in terms of elementary functions. However, since that is a continuous function, it certainly does have an integral. That's why "does not exist" is incorrect.
I have no idea why anyone in your class would have thought the integral would be x+ 1/x+ 1. It should be easy to see that the derivative of that is not xx.
I think the way to show that it can't be integrated in terms of an elementary function is using the Risch Algorithm (see http://mathworld.wolfram.com/RischAlgorithm.html" ). As for what the algorithm actually is, I have no idea!
I read the wiki: I know I'm wrong in the head, according to that, if it is correct. If there is no elementary solution they use computer algorithms to get heuristic solutions which give approximations without proof. In other words only rough answers and there is no suggestion that they will remain infinitely good approximations. Which neatly explains why my maths program tells me to get bent :smile:
well actually it gives the solution
[itex]\int x^xdx\rightarrow \int x^xdx[/itex]
Which is the same thing :smile:
Your first approach was good. Taylor Series. Integrate term-by-term. Then leave it as such. That's all you should do.
[tex]\int_0^1 x^x dx = \sum_{n=1}^{\infty} (-1)^{n+1} n^{-n}[/tex]
You cannot use a Taylor series for [tex]x^x[/tex] centered at 0 because the function is not defined on an open interval containing 0.
Consider the complex valued funtion [tex]f(z) = z^z = e^{z\log z}[/tex] this function is holomorphic on [tex]\mathbb{C} - (-\infty,0][/tex] so as along as we stay away from the branching of [tex]\log z[/tex] we can use the complex version of Taylor's theorem. For instance if we are on the neightborhood [tex]N(1,1) = \{z\in \mathbb{C} : |z-1|<1\}[/tex] then this function is holomorphic on this open disk and hence has a Taylor series expansion. So you need to change you center of series, for instance, for x=1 if you really want a Taylor series.
My understanding of this article is that the Risch algorithm is a decision procedure used to determine the function of an indefinite integral. I don't gather that there actually is an algorithm that proves it CANNOT be integrated in terms of elementary functions. If there is, can someone post it?
The mathematician Liouville showed that [tex]\int f(x) \exp [g(x)] \ dx[/tex] where [tex]g(x)[/tex] is non-constant is elementary for rational functions [tex]f(x),g(x)[/tex] if and only if there exists a rational function [tex]h(x)[/tex] which solves the ordinary differential equation: [tex]f(x) = h'(x) + h(x)g(x)[/tex].
I believe this can be modified to show [tex]\int x^x \ dx[/tex] is not an elementary function.
I'm interested in how this modification can be done. I've had a go at it without much luck.
JJacquelin said:
A compendium of properties of the integral of x^x is provided in the paper "Sophomore's Dream Function" :
http://www.scribd.com/JJacquelin/documents
Great link. Thanks for that. I guess all that's left is to prove that it is indeed a non-elementary integral.
